E40D Transmission rebuilt, Overdrive works. but is in a constant blinking stage.
Old 02-17-2017, 10:26 AM
Resendiz's Avatar
Resendiz
Resendiz is offline
I purchased this truck back in July. The OD light always blinked. But the function worked then and still does today. I took it in to the shop about 3 months ago because the transmission started to delay when shifting gears. The guy said we could try switching the controller pack, but it would most likely need to be rebuilt. I told him about that light and he said it might fix it, but if it does not, we will go for a full rebuild. Since I would have probably ended up purchasing a controller pack anyway when doing a rebuild, I decided to try it. It didn't fix the shifting problem (not related to the OD light) so I said lets do a rebuild.
After the rebuild, the transmission feels great. I can still control the overdrive function, but the light still blinks. I ended up having an engine rebuld right after, so i just got it back. Still blinking though. Anyone know what the rpoblem is?
Old 02-17-2017, 11:03 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
You need to pull codes on it, it could be a few different things.
Old 02-17-2017, 11:13 AM
Resendiz's Avatar
Resendiz
Resendiz is offline
Ok. They still have the truck. If they can't figure it out, I'll buy a code reader. I think i mentioned it to them before, but they said its so old that they don't have or use that kind of reader anymore. I don't want to push them to get one, it might "void" my 2 recent truck transmission warranties if you know what i mean.
Old 02-17-2017, 02:33 PM
Realslowww's Avatar
Realslowww
Realslowww is offline
This is why I think the old C6 with a OD is a much better set up.
My E4OD was acting up and I thought I needed major repairs and the Guru's on this site fixed it. On mine the tranny is wired into the cab light and the cab light was shorting out so the circuit kept blowing fuses and the tranny would not shift correctly with the OD blink going off. Real stupid layout from the factory....
Old 02-17-2017, 04:58 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
You can use a Ford specific OBDI code reader, but it's not required. Here's how to get blink codes:
Ford ? OBD/OBD2 Trouble Codes
F350Bandit
11-11-2012 07:37 AM
landcruzr
12-24-2009 08:59 PM
bchunter
20
07-19-2004 12:26 AM
jeremymcelroy
15
05-27-2003 08:43 AM
russwa
1978 - 1996 Big Bronco
07-19-2001 08:17 PM
Quick Reply: E40D Transmission rebuilt, Overdrive works. but is in a constant blinking stage.
