1950 F4 Build Log
Old 02-16-2018, 10:13 AM
acl9865's Avatar
acl9865
acl9865 is offline
Originally Posted by 49fordv8f4
This is my 9' bed on my F4. The 158" WB would put the wheels pretty far back under the bed. A 158" WB would need a 12' bed to look right. The 134" WB also makes for a lot handier truck. My frame was bobbed at the back for the hoist.
Mark
After seeing this I'll most likely move the rears forward but it'll likely be the last thing I do. My local Sunbelt has mag drills so I'll snag one of those and move them in May.
  #32
Old 02-19-2018, 01:39 PM
acl9865's Avatar
acl9865
acl9865 is offline
Coated the hood in Citrigel, ate through the paint easily. Cleaned the rest off with a paint wheel on my angle grinder before using some Marine Clean and 3 coats of POR15. Think the picture is only after 1 coat then, hence the transparency.
  #33
Old 02-19-2018, 02:56 PM
F1 coyote's Avatar
F1 coyote
F1 coyote is offline
Originally Posted by acl9865
Had the head hot tanked, surfaced, and painted. Off topic but also bought this '43 G8T with flathead 8 for $400.
What color and type of paint did you use on the head?
  #34
Old 02-19-2018, 03:08 PM
acl9865's Avatar
acl9865
acl9865 is offline
Duplicolor Red Engine Enamel? I think I still have the can at home. Same color as my block.
  #35
Old 02-19-2018, 03:34 PM
F1 coyote's Avatar
F1 coyote
Man that red really pops, I been thinking about painting my engine that color. The color of the truck is going to be the original meadow green. I wonder if the paint will work on an aluminum engine? I think I might have to use a special etching primer to ensure good adhesion, I'll have to research that.
I think that red is a great contrast against that meadow green.
  #36
Old 02-19-2018, 05:27 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
It sure is!
  #37
Old 03-03-2018, 05:59 PM
acl9865's Avatar
acl9865
acl9865 is offline
What's next for cab removal?
  #38
Old 03-04-2018, 09:24 AM
acl9865's Avatar
acl9865
acl9865 is offline
Today I'm removing the 4 cab bolts and hoping I can remove the cab. I only have ~6" above the cab until the ceiling so I'm hoping some combination of tilting and lifting works.
Is there anything I can do with the column to allow it to rotate or pivot? I've removed the column support under the dash, I've pulled the panels on the floor around the column but I'm still not sure if I can clear the column. Some pivot on that column would really help...
Advice experts?
  #39
Old 03-04-2018, 12:38 PM
acl9865's Avatar
acl9865
acl9865 is offline
Nevermind, pulled the column. The pitman arm gave me some struggles but I found a jaw puller that worked fine. Cab up next!
  #40
Old 03-05-2018, 09:04 AM
acl9865's Avatar
acl9865
acl9865 is offline
Took me an hour with the cutoff wheel but the cab is free! Over the next 2 weeks I'll get the frame down to bare metal and POR15'd. Then everything will start to get reassembled.
Goal is a running, driving, painted truck by June.
And of course I need to credit my amazing girlfriend for doing all of the paint/rust removal on the body so far..
  #41
Old 03-05-2018, 10:47 AM
abe's Avatar
abe
abe is online now
​​​​​​Good luck with your time table! I hope you reach your goal. With the help of a girlfriend you probably will. She sounds like a keeper!
  #42
Old 03-05-2018, 11:03 AM
acl9865's Avatar
acl9865
acl9865 is offline
Haha ambitious I know. Unfortunately she's gone all of March and I'm gone a few weekends coming up which will slow me down..but I'm also taking off all of April to get some truck work out of the way. Luckily work was understanding about my need to finish up an old Ford and gave me 5 weeks of free time to do it in.
And yes she most definitely is. She's probably more excited than I am to see it finished, plus she did the 37 hour straight round trip drive to Boise to pick it up from my storage..skipping her spa weekend..
  #43
Old 03-17-2018, 04:42 PM
acl9865's Avatar
acl9865
acl9865 is offline
New updates:
Front Axle removed and leaf packs pulled.
Started cleaning the frame to prep for paint.
One brake fully torn apart. Was hoping to get away with wheel cylinder rebuild kits but no they're toast..
Rear wheels off and the three screws holding on the brake drum are not going anywhere soon..
Started cleaning the trans with a pressure washer and a gallon of degreaser. Think the gears look alright ya?
Alex
  #44
Old 03-20-2018, 09:39 AM
acl9865's Avatar
acl9865
acl9865 is offline
Anyone have any input?
  #45
Old 03-20-2018, 10:07 AM
Jafo56's Avatar
Jafo56
Jafo56 is offline
I'm a little a head of you but not far...I did get my motor back in ...wired and running....
Quick Reply: 1950 F4 Build Log
