1950 F4 Build Log
Nice truck! I also have a 50 F4 and serial number is 97HTL 283746
1. Your differential looks like an F4. F5/6 were usually 2 spd rears.
2. What size tires/wheels do you have? F4 came with 17"s and F5/6 ran 20"s but all used the 5 on 8" bolt pattern.
3. What is the serial number on the tag on the firewall? Is it the same as your frame stamping? It's possible a factory screwup stamped for a V8 and the truck got a 6 cyl setup.
4. Last thing, do you have any stampings on the firewall or cowl area that gives the build code?
Nice truck! I also have a 50 F4 and serial prefix is 97HTL 283746
Ya I think the consensus is that it's a stretched F4. Pretty sure these are 20"s...since I stacked them next to my replacement 19.5"s and they were taller.
Firewall tag says same number as frame stamping.
I'm sure I do, but I do have that number off the top of my head. Forgot to grab a picture of it.
Tim, It is my understanding that the F4s came with 18" wheels if they were sold as a dual rear wheel truck and 20" if they were sold with single rear wheels. My F4 had 20" DRW on it when I bought it. It came that way from the original owners family. I don't know if 20" were available as an option or if he changed them later. Oddly enough my serial number doesn't have the "L" in it, so I guess by the serial number it would technically be an F5. But, it is titled as a 10,000 gvw F4 and the F4 emblems are original to the truck.
Mark
Mark
Mark
Mark
I wouldn't worry about the lack of an L in your serial #. Ford assembly plants had more than a few blunders when it came to stamping serial numbers.
I chopped off the last 10" of frame because it looked like someone had been practicing welding and plasma cutting on it, plus I needed to lose that 10" to fit it in the garage. So now it's a 9' bed. I'm going to finish it off first and then decide if I want to shorten the wheelbase. I'm worried it'll look goofy with a 9' bed but a 158" wheelbase.
Very very happy to not have to drive 1900 miles to work on it..15' to the garage is way better.
Alex
