DIY Experiment - Ultra-Capacitor Bank
#47
there are "regulation" components on the field winding of the alternator....but none on the stator winding. The stator winding feeds the 3 rectifier diodes that in turn results in your DC (pulsating) .
so basically, a surge anywhere on the DC side beginning at the rectifier diodes and through out the DC system...would not be protected by the "regulation" components in the field winding.
the surge protection diode in the link is useful for clamping surges above 14.5 volts. its particularly useful if you have one of those plug in your lighter solar panels which do not come with solar regulators ....this diode will clamp voltage above 14.5. some solar panel cigarette lighter charges can produce 21 volts once the batteries are fully charged.
There are other "surge" devices which have a faster response time, which you can put on your vehicles DC power source.
#48
Update November 2017
In October my alternator started to behave badly, it cooked the battery and was eventually recognized through the battery light on the dash due to high voltage. Upon replacing the alternator, I discovered some no name brand 140amp alternator that was not original. The replacement came from Ford at 220amp which is the high output single alternator for the F450. Registered 14.6v at install and going strong ever since.
So currently I have a no name group 65 on drivers side with some 800cca, and my enhanced ultracapacitor bank on the passenger side at 1800cca. It works very well.
https://www.ford-trucks.com/forums/1...f450-6-4l.html
#49
This image shows all the ultracapacitors connected in parallel for the the initial charge, I think I took them all to 2.3v - then I unbolted everything and reconfigured into two banks of six ultracapacitors in series.
My observations:
- With the initial charge in configuration of series, the result is that the individual ultracapacitors will follow a bell curve of varied voltages across the ultracapacitors. As an example: 2.3v, 2.1v, 1.9v, 1.9v 2.1v, 2.3v
- With the initial charge in configuration of parallel, the result is that the individual ultracapacitors are all the same voltage across the ultracapacitors. As an example: 2.3v, 2.3v, 2.3v, 2.3v, 2.3v, 2.3v
The difference is that the total energy available is higher when the initial charge is done in parallel. A significant observation is that over time the consumption/replenishment of the charge follows the pattern of the initial charge.
So after 40,000 miles, my ultracapacitor bank that was initially charged in parallel is still 2.3v, 2.3v, 2.3v, 2.3v, 2.3v, 2.3v with no balancing circuits between the ultracapacitors.
I observed the same thing with the ultracapacitor bank that was initially charged in series, it kept the bell curve across the individual ultracapacitors over time and consumption/replenishment.
Lesson learned is to conduct the initial charge with all ultracapacitors in parallel to achieve equal voltages across the individual ultracapacitors for maximum joules available.
#50
#51
I have sold my truck and transferred the ultra-capacitor bank to a gasoline powered vehicle, and I replaced the concept of a second battery with a Super small 12v Duracell AGM $25 battery. I figure I can replace the Duracell every spring, after winter has torchured the battery. So now I have 1800+5 CCA on a 5l gas motor and it keeps 13.8v thanks to the Duracell - smiles and laughter!
NBC-Steve
18
08-03-2020 08:58 AM
Ballerforlife911
16
02-18-2010 06:46 PM
TNT in Round Rock
06-22-2006 07:59 PM
