New to the IDI forums
Howdy folks. I usually stick around the 73-79 and bronco forums but I just bought my first diesel pickup, a 1990 (I believe, thats what the seller said its a '90, but I will verify that when I pick the truck up. It is a 7.3 backed by a zf5 transmission and it is a 4x4. The lift pump is bad, it needs batteries, likely has air in the fuel lines and needs the correct coolant pronto. I will pick up the necessary components as I go. I only paid $500 for the truck, so I am willing to do a little work on it.
The PO says he was driving the truck and the next day when he tried to start it, it ran weakly and died. Further attempts to start the truck resulted in sputtering and eventually no fire. Does this sound like a failed lift pump to you?
Thanks in advance!
Thanks in advance!
FORD 1990 Bronco, Econoline, F150-F350 & Super Duty Pick Up Truck Shop Manual CD | eBay
Received 3,102 Likes
on
I checked the oil before I bought the truck, and it was at the proper level, and smelled fine, so I don't think there is any fuel in the pan.
on
katman104
03-21-2018 07:40 AM
Andrew James
17
12-11-2017 05:41 AM
whalebus2112
08-16-2012 07:21 PM
