Engine will not idle below 950rpm
Old Feb 12, 2017 | 10:08 PM
Justin73supercamper's Avatar
Justin73supercamper
I have a weird problem. I have a 390 Holley 770 street avenger. A height distributor. I had a wood carb spacer that cracked I replaced it new base gaskets for the carburetor. My timing is at 11degrees base. It will not idle below 950 rpm. I disconnected my throttle linkage. Turned the base idle screw all the way out with not change.I cleaned the primary jets and looked for vacuum leaks. I'm using a digital timing light to set the idle and rpm. I'm out of ideas any body have any?
Old Feb 12, 2017 | 10:24 PM
TheMonson's Avatar
TheMonson
Vacuum leak?
Old Feb 12, 2017 | 11:53 PM
Grandad's Truck's Avatar
Grandad's Truck
Check to see if the valves on the bottom can't close all the way. If you don't have the Holley spacer and you are on the Edelbrock intake, the valves on the bottom can catch just enough to not close all the way.
Old Feb 13, 2017 | 01:36 AM
meangreen92's Avatar
meangreen92
Check your secondary throttle blades and make sure they are closing. Sometimes they can get hung up for whatever reason, resulting in a high idle.
Old Feb 13, 2017 | 07:19 AM
DB429SCJ's Avatar
DB429SCJ
Make sure the choke is all the way off and the fast idle cam is all the way down.
MeanGreen72
Jun 16, 2019 11:31 AM
78Fords
May 22, 2017 09:21 AM
BaronVonAutomatc
Mar 25, 2014 05:23 PM
pinehillian
18
Apr 1, 2013 04:44 PM
oldiron
16
Sep 8, 2006 05:35 AM
