1990 f250 no start issue
Old 02-12-2017, 05:12 PM
wested68's Avatar
wested68
wested68 is offline
hello, have pu with 351, has power to fuel pump and eec relay has spark to coil and plugs and fuel sprays out of schraeder valve on rail when i depress it, turns over but wont light, started fine in fall but got super cold and tryed starting and wouldnt go, warmer now and still wont go, could it be a pcm issue? fuel pump kicks on for 2 seconds like its supposed to and no codes
Old 02-12-2017, 05:20 PM
88n94's Avatar
88n94
88n94 is offline
I suspect the ignition module on the side of the distributor. You need a special tool to remove and reinstall the ignition module, a skinny nose small socket of sorts.
Old 02-12-2017, 07:35 PM
wested68's Avatar
wested68
wested68 is offline
module even if i have spark at plug tho?
Old 02-12-2017, 09:12 PM
88n94's Avatar
88n94
88n94 is offline
No, I missed that in your original post. I usually try to read posts over carefully and read them more than once, I missed that sorry.
I would try spraying some starting fluid in the intake and see if you can get a brief response from the engine.
Desireg
09-25-2015 05:22 PM
1984Ford300six
09-22-2014 02:09 PM
gordsp
27
03-08-2012 02:06 PM
tkrocks
03-23-2005 07:52 AM
F2501988
05-13-2004 10:05 AM
Quick Reply: 1990 f250 no start issue
