Slider or fixed 5er hitch forF350 short bed?
Getting a 2017 F350 4x4 short bed w/5th wheel hitch prep. Will pull a new Grand Design Reflection 5th wheel (307MKS). I think, but not certain, Reflection nose caps are the same across models. Will I be able to safely make tight turns using a fixed hitch or will I need to purchase a heavier slider? Appreciate advice. Thanks.
Get a goose neck ball (Reese, Curt or B&W) and the Andersen Ultimate hitch to go with it. Much cheaper and lighter. I have an F350 SB and have no clearance issues.
http://www.andersenhitches.com/catal...onnection.aspx
http://www.andersenhitches.com/uploa...d%20trucks.pdf
While you may see folks dismiss it because it is different, folks who have them love them. It is becoming so popular that Pullrite has a similar one now, but Andersen has more adjust-ability for clearing the cab. Pullrite doesn't necessarily recommend theirs for short beds.
Here is a link to the manual: http://demco-products.com/assets/use...ts/HJ26077.pdf
From it:
"Because the Autoslide hitch uses capture plates to maintain the hitch head position in relation to the trailer king pin, the trailer can only be coupled and uncoupled when it is in straight or slightly angled alignment. The Autoslide can couple anduncouple up to a 10-15° trailer angle quite easily. Anything over this degree of angle will not allow for proper coupling."
Yea, because of how it works, you cannot unhook at a sharp angle. I tried it once, and it wasn't pretty.
From it:
This is not a problem with the Andersen Ultimate. One of it's delights is not having to have the planets aligned in a certain way to couple or uncouple. It is good to have that be a fading memory.
2 or 3 inches, but who's counting. I ordered the funnel for mine, but won't put it on until spring.
OK, I'm convinced. Perhaps a bigger funnel would give me the extra leeway. Hoping the back-cab camera gives me the line. Is it better to secure the hitch to the truck via the beds gooseneck ball, or to buy a drop in rail box and get the rail-type Andersen ultimate hitch? Another question. With the hitch in place using the standard gooseneck-type attachment, what is the distance from the center of the hitch ball to the back of the cab of a 2017 F350 SB? Like to estimate clearance before buying hitch. Thanks.
