2010 Ford Escape Transaxle leak
I read there was a 'kit' for the 6F35 transmission leaky output shaft seals. The bushings are different between the CD4E and the 6F35.
Check on youtube for vids explainging and demonstrating replacing the output bushing.
Makuloco did one for the CD4E early this year. One poster reported getting a bushing replaced for $120, so do not believe someone who states 'the transmission must be removed for repair.' It may be true in some cases(the bushing has been gone, and the case half is destroyed???) that there must be a disassembly to effect repair, but not all and mostly not.
tom
tom
tom
tom
It all depends on removing the old bushing. Does the hole have a shoulder or not? Either way, you'd need a good puller, one with a expandable collet to grip the bushing is the best. A good old slap hammer with a bit might work as well as long as there is something a catch on to.
Bill, I think there is a video on youtube for the 6F35. Makuloco did one for the CD4E, and I think the 6F35 had more leaks out-of-the-box than the CD4E.
I don't know which of splitting the bushing or using a puller is the correct way to go, but suspect that splitting is likely.
If you watch the video, you'll see that there's not a lot to grab onto, and that particular bushing is pressed against a shoulder, so there's no room for a 'hook' to allow slid-hammer work. I think the other unit is similar, but don't bet the bank.
tom
tom
tom
tom
I've never seen or looked for a video. If they have a shoulder, I suspect they have a special tool to extract the busing. Splitting the case just to knock the bushing out sounds like too much work. I've cut them with a chisel till they snap. Darn oil impregnated bushing like to break up in pieces and that's all one needs is a piece to fly into the gearbox!
Deja vu!
We talked about this back in 2014, here's the link, makuloco2000 video on it's replacement is there, too:
https://www.ford-trucks.com/forums/1...ak-repair.html
From the file I created with all the info gleaned back then:
Left-Hand transaxle leak repair
Joint and Stub Shaft Assembly – for left half-shaft – Motorcraft TX 682
Ford AL8Z-3B414-B
Contains: New design stub shaft/inner CV joint outer housing, boot, boot clamps, grease, trans bushing, trans seal.
Use Loctite 648 (green color) on the new bushing before install.
Tools – need bushing remover with 5 lb. slide hammer, bushing installer, seal installer.
I have not done this yet, nor did I purchase the kit. We just crossed 50k miles, no leak yet.
Ford AL8Z-3B414-B
Ford AL8Z-3B414-B
Ford AL8Z-3B414-B
The puller used was exactly as I mentioned above.
rpatrick
07-11-2011 06:46 PM
HardFordCore
07-12-2005 02:46 PM
