Buzzing sound followed by grinding sound
I have a 09 f150 with 160,000 on it. For the last couple months I was hearing an occasional buzzing sound from the engine compartment. Couldn't duplicate it while not driving. The buzzing sound has changed somewhat but it's follow by a grinding sound that seems like the hubs are trying to lock while in 2 wheel drive. I think the buzzing is coming from either the IWE solenoid or the vacuum check valve. My question is this. If I pull the vacuum line off the the solenoid and plug the line will the hubs remain locked till I can dig into this a little deeper. I was thinking that they would stay locked. I should still be able to shift in and out of 4 wheel drive correct? Any help on this would be great.
Thanks
Thanks
The dealer said they won't replace the hubs because if it doesn't fix the problem they will loose money. They can't find any vacuum problems. So I guess they are not interested in fixing it. I took the check valve off and I can blow air thru it in both directions. I didn't thin that would be possible if it were good. The grinding is when I accelerate. Maybe the vacuum is dropping and the check valve isn't holding vacuum in the hubs.Both hubs are making the noise so I don't think its the hubs. Both wouldn't go bad at the same time.
dogerbrown1
09-22-2010 06:43 PM
