Get Charged with HiddenPower under vehicle battery mount
What other product will give you a charge while your sitting still, having fun, or working hard?
The HiddenPower auxiliary battery is designed to also maintain its charge while RVing by becoming an extension of your RV's battery. When your RV is plugged into your truck, recharge via your RV's existing solar panels, generator, converter etc. at the same rate that your RV's batteries charge.
HiddenPower Features
By adding an extra battery that is tied into your truck's electrical charging system, keep the battery charged and healthy and always ready for RVing with little to no maintenance.
Watch the video below to see how the HiddenPower works.
The HiddenPower allows you to camp using battery power without draining your vehicle’s battery when coupled with the HiddenPower Wire Harness (sold separately).
HiddenPower Wire Harness Features
- Add additional batteries under your truck bed that are always charged up
- Avoid wasting fuel and leaving your truck engine running while using electrical accessories such as lights, stereos, computer, etc.
- Power your accessories without turning your truck engine on by having them directly wired into the extra battery
- No-drill frame mounted with quick disconnect feature for battery service
- Kept constantly charged and RVing-ready by your RV and truck’s charging system
- Hidden when in use with no loss of ground clearance
- Works with group 24 to 31 batteries
- Designed for all types of batteries: lead acid, AGM, sealed, gel cell, etc.
- Legendary Lifetime Warranty
- Proudly made in the USA
- Frame mount bracket
- Group 24 to 31 battery box
- Installation hardware
- Enables your HiddenPower battery to become an extension of your RV battery
- Prevents your starting battery on your vehicle from being drained
- Constantly charged for RVing or other uses by your truck's charging system
- Universal design, works with all HiddenPowers
- This wire harness completes your HiddenPower installation
- Sealed Wire Harness to help protect against dirt and moisture
- Fused to protect your vehicle’s electrical system
- Detaches quickly via quick disconnect plug for battery service
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Thank you for your questions. The HiddenPower is designed to help maintain and provide some trickle-charge battery power, but would not be a significant enough amount to power a fridge.
We spoke to our tech support and they suggested the best thing you could do to power the fridge is connect it to a portable generator of some kind.
Please let us know if there are any further questions we can assist you with!
__________________
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
03-13-2018 07:16 PM
Torklift Sheryl
12-12-2017 05:51 PM
Torklift Sheryl
07-27-2017 07:09 PM
Torklift Sheryl
06-22-2017 06:24 PM
Torklift Sheryl
02-23-2017 04:07 PM
