Got an opportunity to pickup a clean 65 2x long bed with the passenger tool box in the side for a real good price. Would this be an easy swap onto my 65 F100 4x4 with the wrong bed? Other than drilling new holes if needed?
Sure, but isn't the reason for the swap to make it look "right"? It won't ever look "right" with a 2" too wide gap.
I guess I was thinking if I was going to move the axle I might as well move it on a later frame I could get bolt on PS and perhaps a married tranny with auto.
This seller also has a very solid cab for sale. It has a dashpad and trim I'd like to have. I'm guessing that with the front cab mounts being different it wont bolt onto my 4x frame though will it.
Don't forget if you move your axle rearward that much you'd need a longer driveshaft and you'd also alter (reduce) your ground clearance in terms of the driveshaft angle.
Correct. Different cab mounts in the front would require some fabrication.
