1995 F-150 emissions sytem question - Ford Truck Enthusiasts Forums
Old 02-05-2017, 01:15 PM
JF492 JF492 is offline
JF492 is starting off with a positive reputation.
I have a 1995 f-150 5.0. I put a new Walker exhaust on the truck including Y-pipe and cat. The original exhaust had the tube going from the air diverter valve behind the engine down to the original cats. I removed this tube since there was nowhere to hook it up to the new exhaust.
My question is should I just leave the diverter valve not hooked up to anything behind the engine? It seems to be running fine like this.
Also should I leave the TAB and TAD solenoids as they were?
Old 02-05-2017, 07:10 PM
TeeRob's Avatar
TeeRob TeeRob is offline
TeeRob is gaining momentum as a positive member of FTE.
Unless you want to delete the whole air injection system, I would just leave it. I removed mine and it was more work then it was worth in my opinion.
5.8L Smog Pump Delete with Pics mramc1 1987 - 1996 F150 & Larger F-Series Trucks 40 12-07-2017 09:49 AM
1995 4.9L Vacuum Help MusicBro 1987 - 1996 F150 & Larger F-Series Trucks 4 08-04-2017 01:44 PM
Removing smog equipment Plowboy34 1987 - 1996 F150 & Larger F-Series Trucks 3 01-03-2017 11:31 PM
Adding Emissions Equipment Back - 1986 302 scalladaballa 1978 - 1996 Big Bronco 8 06-11-2016 10:49 AM
New to me and in need of advice hidesert rat 1987 - 1996 F150 & Larger F-Series Trucks 9 02-24-2016 06:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
