Transmission Took A Dump but it could be the TC maybe
More updates, believe I just manually got the truck into 2WD using the shaft/spline sticking out the side of the transfer case (front driveshaft now spins freely). TC shaft/Spline is now at the 1-2 o'clock position, but it was an effort to get it in there. I'm not sure how that little motor manages, but it could also have been because nothing is running. I have tested the motor with 12V and it seems ok. Now I am going to put everything back together and see what does/doesn't work!
It's not the transfer case. You said it doesn't roll in park, so the transfer case is in gear and NOT causing this problem.
The metal parts you found in the trans look like part of a one way clutch. Did the trans work with the shifter in 1 or 2? That would help narrow down what you'll find when the trans is torn down, but the bottom line is that the trans has failed. Nothing short of a rebuild or replacement is going to get this going again.
Not saying the trans is not toast but it appears there is something is going on with the transfer case. He has found a bad connection to the shifter motor.
Now that doesn't account for the 4 bits of magnetic material unfortunately. So I guess my question is this - they are metallic and appear to have had an attachment point at one end but not the other. It's possible to tell that one end broke off something while the other end has a proper finish and is very slightly curled up they are very light and thin, bend easily. I can post some clearer pics shortly now I've cleaned up the bits. Hopefully someone can ID them.
I hear ya, I sent them pictures as they are up in CO. They said dip stick parts first until I reminded them it's an F250 then they said sprag, but I'm not convinced if Mark is saying he's not sure. Problem is I know very little about this and the googling I have done hasn't yielded any clues yet - hopefully it's something of nothing.
If things seem to be OK at this point I just wonder if the "parts/bits" are from the previous transmission failure that never got cleaned out. Mine had some "junk" left in the pan (01' with the one way clutch isue) when I had a service done when I fist bought it. No problems or trouble with it but I had some concerns.
#29
The metal pieces look to be part of the "Z" shaped springs from the OD roller sprag. The curved ends, of the broken pieces, would be where the springs are bent
Attachment 173385
Attachment 173385
#30
FORD 4R100 OVERDRIVE SPRAG 98-04 ONE WAY ROLLER CLUTCH TRANSMISSION COAST DRUM | eBay
I concur. That is exactly what they look to be from. Above is a little better photo with ability to zoom.
