1979 Cruise control (sell?) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 01-29-2017, 09:49 AM
427mike
427mike is offline
427mike is starting off with a positive reputation.
Hello,
I have my 1979 Bronco dash completely out. I'm considering removing and selling all the cruise control stuff. Don't think I will ever use it and if its worth money and someone wants it I might let it go. Does anyone know how much I should ask for everything? I would even consider throwing in the tilt column with the factory steering wheel. I just bought this with a bad trans so I can't verify it all works but it is all there, this bronco is stock and nothing has been removed.
Mike
Old 01-14-2018, 04:10 PM
Justinak1
Justinak1 is offline
Justinak1 is starting off with a positive reputation.
Cruise control
I would be interested in the complete cruise control if you have removed it.
Old 01-15-2018, 10:32 AM
427mike
427mike is offline
Bummer. I was hoping to get someone interested before I put the dash back in. I have everything in a box except for the controller and the speedo cables I decided just to leave in. I guess I could see how hard it would be to get the controller out. What is all this stuff worth? If I am right I would need to buy and new speedo cable also.
Old 01-19-2018, 09:00 PM
black & blue 78/9
black & blue 78/9 is offline
black & blue 78/9 is starting off with a positive reputation.
Cruise control
Hello, You asked about how much for the cruise. Two weeks ago I bought a complete cruise for $20 dollars. Both speedo cables, speed sensor, controller, wires to hook this together, vacuum control, vacuum lines, wires that go up the steering colunm, even the brake light switch. I did not get the steering wheel.
Old 01-26-2018, 04:08 PM
Justinak1
Cruise control
Yes you would probably need a new Speedo cable. I would be interested in the complete assembly if you would like to sell it, if it was everything I would be willing to give $100
Old 01-30-2018, 01:54 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by 427mike View Post
Hello,
Mike
Where is the Speed Control switch, on the horn pad (factory) or clipped to the T/S handle (dealer installed)?
Old 02-08-2018, 09:44 PM
427mike
427mike is offline
Sorry, I am having computer problems and did't see these responses.
Justinak1. I will do some home work and see If I can just unplug the controller so I will get back with you. Unless some one on hear can help with that.I would need to find a speedo cable that works for me first.
NumberDummy. First of all. Thank you for all your input on this site, it has helped me a few times.
The controls are the factory ones on the steering wheel but they seem a little loose to me. When i said controller I meant the factory black box behind the dash that the speedo cables go in and out of.
Old 02-16-2018, 02:04 PM
crtjester9
crtjester9 is offline
crtjester9 is starting off with a positive reputation.
not sure about the cc stuff, as that would be a difficult swap for someone. But the tilt column and wheel could pull a few hundred dollars from what ive seen
Old 03-08-2018, 08:26 PM
dmash
dmash is offline
dmash is starting off with a positive reputation.
Mike, I may be interested in your steering wheel pad if not worn too badly. Mine is worn around the horn bar area but the buttons are fine. New pads for non-cruise are available and I would consider buying a new one for you in exchange for your pad. Send me a PM if this seems like something we can work out.
427mike
02-18-2018 11:00 AM
aj3501
02-10-2018 10:37 AM
Mother_Love
01-20-2017 11:04 AM
highoctane74
10-27-2016 05:23 PM
highoctane74
03-17-2016 02:54 PM
Quick Reply: 1979 Cruise control (sell?)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
