2002 F53 Motorhome chassis AC/Heat Blower issue
I have a 2003 Motorhome built on a 2002 F53 Chassis with AC/Heat blower issues. Trouble shooting I've done; Tested all fuses and relays, check to see if all of them have power, I've checked Blower motor resistor for continuity, checked the blower motor with 12V. What I have found is that I have no voltage at the resistor, or at the control unit. Nothing at either location. I have power at all the fuses all the relays and all the fuses and relays have been check and I've also replaced all of them just to make sure. I put in a new resistor just in case nothing. Can any one tell me why I don't have 12V at either the control unit or the blower resistor. What wires should be hot and how can I trace them back to see if there is a break or something disconnected in the harness?
Thank you
Deric
Thank you
Deric
traced wires al morning more confused...
Back of control unit there is no 12v found.
Undocumented relay pink wire goes to back of control unit.
original Ford chassis blower lead goes to undocumented relay.
I traced wires from the control to a relay that's not documented.
I also found the blower wire from the Ford Chassis harness label Blower traced it to the same relay. Replaced the relay still nothing. Power is going into the relay but nothing coming out.
Steve
I think the Pink wire in to the control in the center should be the one with 12v power but I can't for the life of me figure out why there is not 12V there when the key is on and the switch is in a position other then off.
No Steve I don't have any power to the switch or thru it. I'm stumped...
should there be 12V at white arrow middle pink wire?
I've checked both switches the is no voltage going to either switch. The green arrow is the blower speed control, and the white arrow is the MAX/AC-FLOOR-DEF control switch. Shouldn't one of them have 12V coming in to it to go to the relay to energize it or am I backwards? I'm checking continuity right now thru both switches. Will let you know.
I found the culprit
Checked all the fuses all are good... found that I have no 12v power to about 4 of the 6 wires in the connector that's terminated their. I put a 12 volt jumper on the wire that runs the AC/Heater control and the blower works. Sure looks like I have an issue at the two solenoids/printed circuit board/fuse holder for the house batteries and the chassis battery. Just started researching that setup. UGH nothings easy...
Do you know where I can get some information on that setup?
Motorhome is a 2003 Forrest River Georgetown 303
Thanks
