NEW Driveshaft
NEW Driveshaft
Well I replaced my front shaft on my 2008 Ford F-350 from a caspstrocic failure backing into my driveway. Long story short the entire shaft split like a tin can
So I have a little down time with snow for the last two weeks so I decided to remove and replace the rear shaft. Brought it to the driveshaft place and they said it would be a waste to rebuilt it considering it would be about 300$ to rebuild and 685$ for a brand NEW unit. One day later and it's in. Good peice of mind considering I only use this truck for plowing, salting and landscaping and can't afford down time. Who else has replaced their drive shaft ?
I had the same problem on my 2006 F350 - front shaft rusted bad in one spot and when I was pushing into a snow bank with the plow, it exploded. Replaced the whole thing with a brand new one the local bone yard happened to have, and also had the busted one rebuilt for a spare.
Here’s a little additional story. I never added weight to my truck, figured the lighter it was the less damage was likely when hitting things plowing. But after the above incident it got me thinking I was probably wrong to not add weight, as with no weight in the back, the front axle is probably doing 90% of the work.
Personally if a drive line shop told me it made more sense to buy a new shaft instead of them rebuilding your old one I would question their quality. I have had several rebuilt over the years and the shafts rebuilt/built by a good drive line shop are much stronger and more reliable than the original, they use a thicker wall tubing and tend to actually build the shaft "straighter" than OEM, every one I have ever had done actually took less weight to balance and had less vibration than new OEM.
SpencerS
11-05-2016 09:22 AM
jfitzgerald001
04-19-2011 05:32 PM
79f-250custom
06-08-2009 10:04 PM
