air ride
I also have the Firestone air bag assists on my F-350 dually.
Am I correct in assuming you want bags on the trailing end of the rear leaf springs, or are you talking all the way around? What are you trying to do, slam it?
IMO, the trick is to remove leaves to get the ride height lower and then take the weight off the leaves a bit with the air bag and recover your ride height. Then you are mostly riding on air.
Switching to all air ride without springs is slick, but remember what all the leaves do for you. Not only do they hold up the vehicle, they also locate the rear end or front end. So without the springs, you need locators.
My non Ford late model pickup comes from the factory with a cushy ride which is nice. But, as soon as I add any weight to it, it hits the bump stops.
Firestone makes a Ride-Rite kit specifically for my truck because of this. Bolts right in where the bump stop goes. I bought the on board compressor so I can adjust as needed without stopping to find air. Works great and I still have the stock leaf springs if I lose air for some reason.
Air-ride also makes kits like this. I think there are universal kits as well if this is the route you want to go.
You might want to talk to the folks at Posie's Rod & Custom. When I bought a set of their Dual Flex springs for the front of my '50 F2 they suggested that I might want to add air bags to the front if I find that I bottom out against the stops too much. Basically they would act like cushions. I've had no need to do this yet but my use has been very limited.
BobbyJ
03-09-2008 08:04 PM
