Sterling Axles
The Dana is stronger and bigger, just like everything else about this truck. That's why max towing capacity of a SRW is up to 20,600 lbs, 21000 in 2wd. Dana hasn't released a lot of info about the new axle but IMO this is all a good thing. It's an example of how ford reinvested the weight savings they gained from aluminum and made the truck stronger and more capable.
The Sterling is a very good axle. It was used under all the single-wheel 2011-2016 trucks, which included F-350 diesels with 440HP and 860lb-ft. None of them were breaking!
Some people have seemed disappointed to get "another" Sterling 10.5, but I surely wouldn't be - its a great axle.
The switch to Dana could be a supplier agreement, a production capacity shift, or simply because Ford felt the new axle would be a better match for the up-rated capacity on some of these new trucks.
The upgrade to the 2017 HD 250 Diesel is around the cost of a F350 diesel, that's why for me it was a no-brainer to go to the F350.
