2003 F150 XLT 7700 4x4 5.4 Triton.
While accelerating normally from a stop the transmission? shifts into 2nd with a heavy jerk. All other gears normal. It doesn't do this under hard acceleration or under very gentle and slow throttle application.
Is this a COP issue, a transmission issue or just a driving style thing?
Thanks. Randy.
Thanks. Randy.
It has 170,000 miles and I have had it for a month now. The 5.4 was replaced by a dealer with a new reman Jasper 5.4 about 50,000 miles ago. Don't know about a trans service. The only "missing/stumble" I have found happens while driving up a steep grade under load and then only very slight. So slight it could just as well be cheap gas as a COP going.
I'll get some carb spray and mist around the vac lines and see.
The accumulator spring doesn't require tear-down, see service manual.
