New to this forum, where do I find towing specs F350
Old 01-23-2017, 05:48 PM
Rottenbiker's Avatar
Rottenbiker
Rottenbiker is offline
I have 94 F350 7.5 auto with overdrive and wanting to know how to find out Cgvwr for my truck. There is nothing on door plate and I don't have owners manual. Rear end is 12 bolt posi 4/10. Any info would be appreciated as I want to move up to a larger fifth wheel then I currently have
Old 01-23-2017, 07:55 PM
senix's Avatar
senix
senix is offline
Received 1,400 Likes on 997 Posts
going back that far is difficult.
I think 10K Is the towing limit though.
Old 01-23-2017, 07:59 PM
69cj's Avatar
69cj
69cj is offline
There are some earlier forums on FTE. You might try there. Good Luck.
Old 01-23-2017, 08:02 PM
senix's Avatar
senix
senix is offline
you can try here:
1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
I'll leave this one here in case someone stops by that knows.
Old 01-24-2017, 07:53 AM
Rottenbiker
Thank you, much appreciated
Old 01-24-2017, 09:06 AM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,076 Likes on 978 Posts
What DO you have now?? Me thinks you will need a newer truck with better towing specs without even knowing.....
Old 01-24-2017, 11:40 AM
L3dford's Avatar
L3dford
L3dford is offline
here's a link to a OM for a '96 if it helps. Around page 224 are the towing tables.
http://www.fordservicecontent.com/Fo.../96f23og1e.pdf
Old 01-24-2017, 12:47 PM
Rottenbiker
That would be great if I was rich and could afford a newer truck, but this one I own and it has been gone through with lots of improvements and upgrades, as well as engine and tranny rebuild 100,000+ miles ago. Truck is pretty sound and runs great. I'm not wanting to go much bigger with fifth wheel only about 5' longer and from looking at weights of trailers I am looking at should be well within towing specs, after the info I've gotten here. Thanks so much everyone for all the info, glad I found this forum! I am single female but grew up working on vehicles and motorcycles. Just don't always have all the info, (and sometimes strength or size for working on big vehicles) I have back passenger side door apart right now trying to figure out why manual lock will not move at latch. Lubed it but still can't get lever to move. Button and rod work but where it goes thru plastic clip into lever the lever won't move. Hoping I don't have to replace whole latch mechanism. Anyone had one of those apart? Repairable?
Old 01-25-2017, 10:31 AM
BPofMD's Avatar
BPofMD
Doesn't matter hoe old/new the truck is or what improvements you have made.... it depends on safety and the original Ford numbers. Depend NOT on how much you can tow.... it's how much you can STOP that counts!
Old 01-25-2017, 12:16 PM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,460 Likes on 1,284 Posts
Reading through that PDF sure does show how the trucks today have improved as towing beasts. Make you wonder what another 10 years in advancements will bring besides a larger $$ on the MSRP.
Old 01-25-2017, 12:41 PM
BPofMD's Avatar
BPofMD
sorry duplicate
Old 01-25-2017, 12:44 PM
BPofMD's Avatar
BPofMD
You never did say what you are pulling now.... Do you know what IT weighs and the pin weight? It'll be the pin weight and the tire limitations that'll stop you with the bigger RV.
Old 01-25-2017, 06:27 PM
Rottenbiker
Pulling a 30' PrimeTime crusader fifth wheel 8500lbs actually rated for half ton but I wouldn't pull with half ton. I'm getting Anderson hitch to lighten the load
Old 01-26-2017, 10:15 AM
BPofMD's Avatar
BPofMD
Good choice.... but I am biased.....
Old 01-26-2017, 11:11 PM
sirkingdra's Avatar
sirkingdra
sirkingdra is offline
Hey there. I actually just created this video that may help you in your journey of trailer towing. If you watch the video I hope you found it to be useful and educational
https://www.youtube.com/watch?v=LWNw2LCDDtU
Also BTW I just recently installed a Reese Fifth Wheel Hitch in my 01 F350 Long Bed, and also scored myself a Goose Hitch to go with the Fifth Wheel
Quick Reply: New to this forum, where do I find towing specs F350
