1985 f600 forestry package (Aerial lift/chip box) project - Page 12 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
  #166
Old 10-25-2017, 02:58 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
If I remember correctly, that carb kit you got was for the original carb, right? If so, the power valve is correct.
Let me ask this: If you're sitting at idle in neutral, and you gun the gas and let off, does the exhaust show any black smoke? Does the engine just rev up like normal, and not stumble? And under load, the same thing, it just accelerates and acts normal? If so, the accelerator pump doesn't really need any modifications.
  #167
Old 10-26-2017, 05:09 AM
raystankewitz's Avatar
raystankewitz raystankewitz is online now
raystankewitz is gaining momentum as a positive member of FTE.raystankewitz is gaining momentum as a positive member of FTE.
Folks, keep in mind the 500 cfm Holley list 4412 was designed and built as a race carburetor, not really meant for the street. Why Holley doesn't state this fact in the catalog, I don't know. Huge internal passages, big transfer slots, big jets and that 50cc REO squirter. Meant for iron head, iron manifold spec circle racing that do not allow carb mods past jetting and maybe removing the choke and choke horn. These are mall block V8s that turn upwards of 7500 rpm (yeah, it can be done).
What was on the F600/370V8 was a 350 cfm Holley that probably, based on my intarwebs snooping, had #62 jets and a 6.5 power valve. A bunch smaller, easier to tame.
Idle mix on that 500 would be easy - just adjust until it idles as smoothly as possible without loading up. Don't have the idle speed screw turned in too far, as this will expose the transfer slots, adding a butt-load of fuel. No Bueno for setting the idle mix.
Throttle tip-in is going to be the hardest to tweak. I would go down to the 30cc squirter and get the assortment of accel pump cams. Find one in the middle range (should be a chart with the kit) and check throttle response under load as well as statically.
Holley 20-12: Accelerator Pump Cam Assortment Includes 8 Different Cams | JEGS
There is a video tutorial on that page for you.
Okay, the main jets. Since you can't stick your truck on the dyno and test all day, that method is out. Yeah, revving it while stationary and looking for black smoke is somewhat valid, it's not that accurate, either. At any rate, you will be changing jets from experience. This new garbage gas we have to run makes plug color testing real hard.
Question to the OP; can you get "Farm Gas", the stuff with no alcohol in it? If so, you can set your jets by plug color testing. Get the engine warm, then take off down the road like a bat out of hell. Get into top gear, let it pull hard for 10 to 20 seconds, then cut the ignition and shove in the clutch. Let the engine quit turning as quick as possible as you stop. Pop the hood, pull a nice hot plug from either #1, #4, #5 or #8. Farthest from the carb. Try not to burn your paws while you're at this. In good light, look at the bidness end of the plug.
Black center electrode ceramic insulator means you're waaaay too rich. Go down a minimum of two jet sizes. Medium brown, try going down one jet size. Tan, where you can say it's tan, is good. If you have to guess if it's white or tan, maybe go up one jet size. White, or white with black specks, waaay too lean. Up two jet sizes minimum. BTW, those black specks are off of your pistons. Yeah.
See how this is complicated, to the point I can't just say put #XX jets in and go? I mean, the #73 jets might work but it will probably be too rich. I ran #68 jets and I think it was the brown cam in my sportsman Fox body T-bird. 9.0 to 1 351 windsor, early 351 heads, I think the manifold was about a '73 or so cast iron piece, Huge lumpy cam with cast iron exhaust, T&C Toploader 4 speed, anywhere from 4.11's to 6.00 gears, depending on the track. 3200 lbs with my fat butt in the seat. On real short bullrings, we ran the 350 cfm carb if it was allowed.
I guess I should say, I would recommend getting the blue bowl gaskets, if you don't already have one in place. Might not hurt to have a spare set (bowl and block).
You did say you wanted to be a Master Holley Carb Technician, right?
  #168
Old 11-09-2017, 08:27 AM
Diymechanicmike Diymechanicmike is offline
Diymechanicmike is starting off with a positive reputation.
Hey thanks for all the great info... Unfortunately I got busy again and had to push project to side again but as soon as I finish job I'm doing should have time to get back at it .... And a holly carb technician I will be after this haha probably a good thing tho cuz gonna have truck for a while
  #169
Old 11-28-2017, 09:32 PM
Size:  422.9 KB is this the carb you were saying would work with the 370 ford engine?
  #170
Old 11-30-2017, 03:06 AM
Jackpot!
Quote:
Originally Posted by Diymechanicmike View Post
<clip images for brevity> is this the carb you were saying would work with the 370 ford engine?
That, my friend, is the best all around 2bbl ever made in my opinion. Used from little 255/260 small blocks all the way to 390 FE big blocks. Good price, as long as they don't gouge for shipping.
It will need a manual choke cable, if you don't already have one. Generally, just bolt it on, turn the idle mix screws in to gently bottom, then out two turns. Fire up, set idle speed, go. Choke might need a bit of adjustment, too but it's not daunting. It comes with good instructions and it is infinitely tunable. Should be good out of the box for you with the exception of trying some accel pump cam experimentation. You might need a bit more, a bit sooner for your heavy truck.
I've ran this on International SV series motors, 304, 345, 392. Ran like a champ on any of them. The 392 in my T-All needed the cam moved to the #2 screw position. That is explained in the instructions. Had one on a 260 in a shoebox '64 Falcon and a '69 390 in an F250. Very versatile.
  #171
Old 11-30-2017, 09:19 AM
Sweet gonna place order now and yeah it's free shipping so $322 is the full price you know if my 4412 carb is worth posting on Craigslist for sale cuz I don't need it and would like to get sumthing out of it besides all the waisted time on it haha if not I guess I'll jus let it dust bunny up sumwhere til I buy a race car that needs it haha (probably won't ever happen tho)
  #172
Old 11-30-2017, 01:12 PM
Yeah, put it up on CL and see what you can get for it.
  #173
Old 12-07-2017, 04:14 PM
So got the new carb like in 2 days from ordering it luckily I'm located near Kentucky where the holly manufacture/distributor is located so she came quick got it put on and wow she started up tuned the idles screws a bit to get it to run a bit better and Wah Lah she fires right up everytime now im amazed finally it appears things are panning out for me haha gonna be taking it for a test drive this weekend to see how she drive with new carb
  #174
Old Yesterday, 12:37 PM
Good to hear you're making progress now. Do post back and let us know how the test drive goes.
BTW, got any takers on that 500cfm Holley yet? LOL!
My first time ever paint job (thread) SlikWillie 1973 - 1979 F-100 & Larger F-Series Trucks 99 11-25-2017 08:41 PM
Ford 400 Cam Options Ford77Pickup 1973 - 1979 F-100 & Larger F-Series Trucks 19 08-29-2017 05:25 PM
Crazy Situation Sidvicious 1999 to 2016 Super Duty 7 06-12-2017 04:50 PM
Tranny Issues? dfdiamond 1967 - 1972 F-100 & Larger F-Series Trucks 16 10-26-2016 05:04 PM
1999 f150 starter is good but wont start. taylerallen6 1997 - 2003 F150 8 06-21-2016 07:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
