Zf-6 problems, advice needed
Ok, my clutch has been giving me trouble for a little bit and I'm almost positive that I have a bent release fork. It also slips under heavy acceleration in 6th gear. I am planning on doing a clutch, compete with flywheel and release fork and a new rear main seal. My problem is, here within the last couple of days the trans would pop out of 4th gear if I was just coasting. It has been getting noisy over the last few weeks also. I'm no manual tyranny expert, but this is making me think I'm gonna need to have it rebuilt. Does anyone know of a transmission shop that will build a ZF-6 stronger than stock?
Depending on your location (help us out a bit here if you want), this place is said to be top notch too.
Welcome to All Star Standard Transmission!
Wow, that seems a bit much, guess your next step is to call some of the places listed above to see what you can find out?
Not sure if this is exactly what you need, I found this under the "new transmission" section, not rebuilt. So, it seems that Midwest has much better prices from the get go.
http://www.midwesttrans.com/webapp/p...rtNum=MTFRD059
Also, I believe this is the link to the other shop Timmyboy76 mentioned. http://www.joestransmission.net/
