Nasty Rattle!!
Old 01-21-2017, 03:37 PM
muskydawg's Avatar
muskydawg
muskydawg is offline
Nasty Rattle!!
Afternoon gentlemen! My 7.3 is making a painful sounding rattling noise. The closest I can pinpoint it, it is coming from the turbo area. It does however clear up when you give it a couple hundred RPM's. It is pretty destructive sounding at idle, and when the truck first shifts gear while you are driving. The oil pressure gauge shows normal pressure, and the oil is topped up. The truck has run with low oil on a couple occasions (the rear main seal leaks...)
Anything I can do to test the turbo for problems? I don't want to remove it if I don't have to.
Also, if it is the turbo, should I look at putting a bigger aftermarket one on? The truck does a lot of heavy towing and snowplowing. Everything else is stock. If I upgrade the turbo, do I need to upgrade other things to see the real benefits?
Thanks fellas
Old 01-21-2017, 05:25 PM
farmert's Avatar
farmert
farmert is offline
Pull the intake hose and see if the fins are contacting the housing. See if there is any side to side movement of the shaft.
Old 01-21-2017, 08:40 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,186 Likes on 815 Posts
^^ What he said just verify if it really is your turbo and not something else. But since you mentioned you have ran it low which in our engines it is harmless thanks to the HEUI injection.
Old 01-22-2017, 08:06 AM
muskydawg's Avatar
muskydawg
Thanks boys, going to check it out right now!
Enez
1999 to 2016 Super Duty
07-23-2018 07:35 PM
9228.bobcat
08-02-2014 07:46 AM
chewedtoothpick
03-20-2013 09:19 AM
91dirtydiesel
20
05-23-2011 12:53 AM
weekendwarriorfsw32
11-26-2009 07:42 PM
Quick Reply: Nasty Rattle!!
