Regret your 3/4
$65,000 invoice pricing
-$1000 customer cash rebate
-$750 Ford private cash rebate
-$500 AQHA rebate
Final Purchase price = $62,750
Not true. Only a diesel on 37's will work as a substitute for Viagra while driving to the mall.
So, no, I don't regret it. If I had a do over I might consider the 350 just because it isn't that much of an upcharge, but it isn't something that I genuinely regret.
why hey would you go to a 350? Better tow rating or?
Gas no Power
Diesel pure power
I do regret very much not buying more truck. You can read all about it in my DRW conversion thread. In that thread I priced an F450 at just a few thousand dollars more than my F250... and I really think the F450 was a little higher because I added some options I now know to look for -- like the camper package.
I want to state that my F250 is incredibly awesome! I love it, and it makes me happy all day long every day. But when I look back and see that I could have a 'sky is the limit' truck for the same money, I just kick myself.
You *can* make the F250 into (basically) the same truck as the F350 with less than $1,000 of modifications -- although nobody will give you credit for it as far as your payload sticker.
But if you haven't signed the papers yet, why not just get an awesome payload sticker, better resale, future proof yourself and get an F350 or better?
All of the Super Duty pickup trucks for 2017 utilize the same exact frame, transfer case, driveshafts, front axle, and front suspension. If the trucks are diesel, they utilize the same exact engine and transmission. From there, the difference between a 250, 350, and 450 involves different rear axles and different rear leaf suspensions. The 450 differentiates itself slightly more by offering a 'wide track' front end for tighter turns and larger brakes (because they can fit in the base rim size of 19.5).
You can say the 450 is "the most truck" and it is mostly true. It has the highest tow rating, a whopping 500lbs more than a basic F-350 dually diesel. It does NOT have the highest payload rating (F-350 dually does) but when it comes to engine and transmission...no different than the "lowly" F-250.
So basically, what is your pleasure? An F-250 is the same Super Duty truck as the rest, but with the user in mind who will need to pull or haul something a bit much for an F-150, or just prefers to drive an HD truck. It will ride the best, it will be the quickest accelerating, get the best fuel economy, and be the cheapest of the Super Dutys...and manage to avoid registration penalties in most jurisdictions.
The 350 SRW is the same truck, but with a higher GVWR and typically a higher payload. The tradeoff is very small...usually the ride quality, price increase, acceleration, and fuel economy are all very similar. A 350 with the upgraded M275 axle and extra leaf might weigh slightly more, causing an ever so slight difference in fuel economy and acceleration, but we are talking negligible differences. Most people go this route because the door sticker legally lets them do more, and the payload may be legitimately higher due to stiffer leafs and / or extra leaf.
Finally, you get to the dually 350 and the compromises become a little more severe. Ride quality is noticeably worse, fuel economy is most definitely worse, and you now take up more of the lane on the road and parking can be more of a chore. You are limited to a 17" wheel. Obviously the benefits include pretty much the best payload ratings, higher tow ratings, higher GVWR, and a more stable tow platform for very heavy trailers.
Lastly is the 450. All of the same compromises apply to this truck as to the 350 DRW, with additional compromises being potentially an even worse ride if max psi is run in the tires unloaded, being limited to only the 4.30 gears which will provide the worst fuel economy of any Super Duty pickup, and having very limited tire options...and for now, the lack of TPMS. What you gain is the very best tow rating, a great payload, the coolest-looking truck...and surprisingly, a much improved turning radius over similar long wheelbase Super Dutys.
If your purpose was to drive up old fire roads to a hunting camp, or other off-road driving, DRW is a major liability...as it long wheel base.
So basically, the folks who "regret" buying a 250...unless you bought a truck that cannot do what you wanted it to, are basically complaining that they didn't buy a truck with a stiffer suspension and extra wheels...hmmm
