Truck rolled into ditch while in park
First time post, apologies if this isn't the right forum.
I parked my 2010 F150 XLT at work and went inside, 10 minutes later it had rolled 25 feet and into a ditch. Thankfully it didn't hit anything or anyone.
My first thought was that I had somehow forgotten to put it in park but when I went over to the truck, I checked and it was still in park and the display "lit up" on the "P". Also, a buddy of mine pointed out that the key won't come out unless its in park.
And so my insurance is taking car of the damage but right now I'm driving around with my "parking rock" because my parking brake doesn't work and even if it did, I want to know the root cause of what happened for peace of mind that it won't happen again.
I never use the parking break and my truck was in 2WD at the time.
Luckily it was a shallow ditch and so I threw it in 4WD and backed out.
Any insight would help, I checked Ford's website and called there customer service line and there are no recalls on that model year.
Thanks in advance!
Thanks in advance!
The most common cause for this is the transfer case stuck in neutral, or the parking cable incorrectly adjusted.
Does that 2010 use a cable to connect the shift linkage to the transmission?
If it's anything like my Navi, that shift cable has a plastic adjustment do-dad where it connects to the tranny. The adjustment may have come loose or the ball stud it fits over may have worn, so when you put the shifter lever into park, the tranny itself may actually be somewhere between R and P.
FWIW, I grew up in northeast OH; we got (and they still get) a lot of lake effect snow. For the last 19 years, I've lived in Louisville, KY. We get some snow here; and we also get ice storms here.
Nonetheless, early on in my driving career, I did have my parking brake freeze up; upon having it serviced, the mechanic recommended I use the parking brake every time I park. He said the daily use was good for the parking brake system keeping it corrosion free and less likely to freeze in place. I have been using my parking brake every time ever since. Moreover, I'm certain to apply it prior to releasing my foot from the main brakes; and don't release the parking brake until my foot is on the main brakes; this keeps me from ever loading the parking pawl in the transmission with the weight of the vehicle (or my trailer when towing). That horrible CLUNK when someone shifts out of "park" when the parking pawl has been loaded with the weight of the vehicle makes me cringe. I know, I'm very '****' over this; but it seems to work.
Yep, once on my '99 Explorer (2 vehicles ago) and it was rather frustrating.
Yep, they can freeze up when used infrequently. Last month our van was in the shop waiting for parts for the wheelchair lift. Made the mistake of setting the parking brake on the loaner van...two hours later it was behind a wrecker on the way to the shop after I couldn't get the damn thing to release.
Sorry for the delay in responding, thanks for all the suggestions. I took it to my local dealer and they are saying that the cable than runs from the shifter to the transmission had stretched and so while the shifter handle said it was in park and allowed me to take my key out, the transmission was not in park. I'm not sure if stretched was the word he used, he said there "was play" in it. Anyways, he seemed quite competent and confident this was the issue.
I haven't been able to re-create the issue, whenever I put it in park the truck won't budge. Repair is taking place tomorrow and so I'll try and get a better explanation.
