2016 F150 factory trailer hitch - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2015+ F150
Reload this Page >
2015+ F150 Discuss the 2015 Ford F150
Old 01-19-2017, 11:19 AM
jjlrrw
jjlrrw is offline
jjlrrw is starting off with a positive reputation.
I have noticed many of the factory and aftermarket hitches start to show surface rust from inferior paint, not just Ford most all makes. I was looking at the hitch and it looks like it is held on with 2 large bolts and three smaller ones on each side, the housing that holds the wiring connectors look to be different piece.
I was thinking of removing the hitch and sanding it then painting with duplicolor truck bed liner paint, I did this with a Curt hitch prior to installing on our Subaru and so far it still looks great compared to other vehicles where this hitch was installed about the same time.
Is removing and reinstalling the hitch straight forward or is there some gotcha's I need to be concerned with?
FYI I do live in the southern lower 1/2 of Michigan where they spread a grain or two of salt for every snow flake that falls.
Old 01-19-2017, 07:01 PM
Tom's Avatar
Tom
Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
I think this would be more trouble than it's worth.
I don't have the shop manual for the '15+ trucks, but they've always required the replacement of the nuts and bolts if the hitch is removed. Some models even had a bolt that had to be cut off with an air chisel to discourage people from removing the hitch.
Every winter I spray the underside of my truck with Fluid Film. I'm midway through my second winter with this truck and the hitch looks flawless. Takes about 30 seconds to spray the hitch in the fall and you're avoiding the hassle and potential liability of a hitch separation if the hitch isn't reinstalled properly.
Old 01-19-2017, 08:37 PM
scott91370
scott91370 is offline
scott91370 has a good reputation on FTE.scott91370 has a good reputation on FTE.
When you say hitch you mean the large part that the ball/shaft go in?
To remove it there are about 8 bolts to take the bumper off, plus unplugging the wiring. Then I think 8 more to remove the hitch. Not terribly difficult but having a second set of hands is helpful.
Old 01-23-2017, 09:32 PM
ExcursionPSD
ExcursionPSD is offline
ExcursionPSD is gaining momentum as a positive member of FTE.
This welded assembly is called the RECEIVER. It includes the 2" square socket for the ball mount or equalizing hitch head.
Old 01-23-2017, 09:43 PM
scott91370
I know the difference but I wanted to make sure which part was being asked about since the title and description sounded like different parts.
Old 01-26-2017, 04:10 PM
jjlrrw
jjlrrw is offline
Maybe terminology got the best of me, the part I am talking about is the part that come already bolted to the truck from the factory.
Old 01-26-2017, 05:36 PM
scott91370
That's the receiver. That is the part I posted about removing above.
It's not terribly difficult but having someone to help remove and reposition it makes it much easier.
Old 01-26-2017, 06:19 PM
T diesel
T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
dynocompe
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
12-15-2017 04:16 AM
Billyclub
2009 - 2014 F150
64
11-02-2017 12:15 PM
BONE DR
2017+ Super Duty
30
06-09-2017 02:42 PM
pancake
12-29-2016 10:50 PM
Jace2016
2017+ Super Duty
27
10-28-2016 07:34 AM
Quick Reply: 2016 F150 factory trailer hitch
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
