RPM Goes Up and Down At Will
91 F-250 5.8 E4OD, as said idle goes up and down weather at idle or cruising down the road a 55. It will be idling just fine at a stop light then all the sudden it will jump up to 13-1400 rpm(good thing I was on the brake hard), when cruising at 55 it will jump 4-500 rpm. The trans is also doing some weird shifting stuff. No I haven't pulled codes yet, I actually have battery unhooked and gonna leave it unhooked all night to clear codes cause I know it had some in it from not having an O2 sensor hooked for a little. Going to take it for a little drive in the morning then check the codes, just thought I would ask if maybe something common causes this problem since I am not the greatest EFI (old man) person. Appreciate any thoughts and help
fordmudgrappler
12-01-2010 08:40 PM
