Brians project Road Rash - Page 20 - Ford Truck Enthusiasts Forums
Old 03-12-2018, 07:23 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.fe390pc has a good reputation on FTE.
Awesome work as usual Brian. So I hear you are going to get slammed again. My family is in the South Shore and they are looking at 18"+ this time to go with last weeks 60+ winds!
  #287
Old 03-13-2018, 07:20 AM
67nukeford's Avatar
67nukeford
67nukeford is online now
67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation67nukeford has a superb reputation
Originally Posted by Brian1971f100 View Post
Thanks Pat, I did sweat a little getting it clean. I didn't take a picture after I OSPHOed. Looks like I will get a little time tomorrow as the next noreaster coming in and work decided to be closed, and by the way my 2nd cab corners arrived. Big difference in the quality. I will post up some photo's later.
Hopefully you guys don't get too much white crap! Be safe out there!
  #288
Old 03-14-2018, 08:25 AM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.
Originally Posted by JEFFFAFA View Post
2X. I wouldn't be opposed to eating my breakfast off that bad boy.
I don't know if I would go that far. LOL Thanks Jeff.
Thanks fe390pc. I think they over publicized this storm, I'm sure Boston got a little more. We were in the 12"- 18" range. Wind didn't seem to bad. The real problem is the ground isn't frozen and plowing up the lawn sucks..
Thanks Pat, I am ready for spring myself, but Mother Nature seems to have other plans for us.
  #289
Old 03-14-2018, 08:47 AM
Brian1971f100
Well I was able to get some good stuff done yesterday. I got the outer section of the rear cab support replaced. Then moved on to the inner cab corner.
I cut out the old, OSPHOed the sections where I wouldn't need to weld. Used weld-thru primer on the parts that will see weld. Finished trimming the patch panel, then screwed it into place and went to town with the welder.
I think I've broken 3 small flat-head screwdriver aligning panels so far. Not to mention how many spot weld cutter blades I've killed.
New panel all fitted and looking good.
I am ether getting better at welding or better at grinding. It didn't take much cleanup to get it this far.
I started the inner cab corner. I thing it will work out nice.Here is the first couple cuts and folds.
  #290
Old 03-14-2018, 08:52 AM
67nukeford's Avatar
67nukeford
Nice patch work!! Oh, you made the inner out of an outer corner piece. Nice!!
  #291
Old 03-14-2018, 08:59 AM
Brian1971f100
Thanks. Yes I figured the shape is very similar and they were cheap enough I would give it a try.
  #292
Old 03-14-2018, 09:02 AM
67nukeford's Avatar
67nukeford
That looks like it'll work out well
  #293
Old 03-14-2018, 09:16 AM
Brian1971f100
So far so good
  #294
Old 03-14-2018, 09:24 AM
67nukeford's Avatar
67nukeford
Take a few extra pics, and measurements. Might be good for some of the guys here, if they need to do the same!
  #295
Old 03-14-2018, 09:25 AM
Brian1971f100
Will do. I find pics can say way more than words.
  #296
Old 03-14-2018, 11:47 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is online now
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
If and when this works out you might do a separate thread on it Brian. Future Kingdom folk and g00glers could find it easier.
  #297
Old 03-14-2018, 02:59 PM
67nukeford's Avatar
67nukeford
Now that's a good idea. That Jeff, always thinking!!
  #298
Old 03-14-2018, 03:12 PM
Brian1971f100
Already had a thread started.
And that's why he's the king.
  #299
Old 03-14-2018, 08:04 PM
JEFFFAFA's Avatar
JEFFFAFA
Thanks Guys. Just helpin' to keep The Kingdom the Best dang forum around. I wear my Cowboy Hat proud. I work hard, play hard, always do what's right, never lie, and always there with a helpin' hand. . Including HERE!
  #300
Old 03-15-2018, 02:43 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
I hope it works out OK too. I'm sure that I'll be doing that same thing, sooner or later.
Quick Reply: Brians project Road Rash
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
