Radials on wheels meant for 60's bias tires.
Old 01-17-2017, 04:57 PM
6t6merc's Avatar
6t6merc
6t6merc is offline
There was recently some discussion about the use of modern radials on our old wheels. I've done it on many trucks and cars, but the discussions worried me a little as I have radials on my '66 15" wheels. Here's an opinion (sorry about the length) from someone who should know:
"No one has ever identified or explained how a radial tire can actually cause additional stress on a rim. I’ve read and listened to opinions and that’s all they are is opinions unsupported by scientific testing data. I believe this myth is backwards. I believe radials cause less stress on rims than the old rigid bias ply tires.
The Department of Transportation has created the new FMVSS 139 (Tread Act)* for the purpose of “establishing new and more stringent tire performance requirements that apply to all new tires for use on light vehicles.” Here is the DOT’s assessment of the differences in performance characteristics between bias and radial tires.“A bias passenger car tire carcass is typically made up of two or four plies of cord material that run from bead to bead at an angle of approximately 35 degrees to the centerline of the tire. This type of construction provides a very strong, durable carcass for the tire. Because the ply cords criss-cross and all the cords are anchored to the beads, the carcass is stiff and relatively inflexible. This type of construction prevents the different parts of the tire from acting independently of another when forces are applied to the tire. As a result, a bias construction is susceptible to impact breaks because it does not easily absorb road irregularities.” This causes more rim stress.
“By comparison, a radial passenger tire carcass is typically made up of one of more plies of cord material that run from bead at an angle of approximately 90 degrees to centerline of the tire. Because the cords do not criss-cross and because the opposite ends of each cord are anchored to the beads at points that are directly opposite each other, the radial tire carcass is flexible. The radial tire is reinforced and stabilized by a belt that runs circumferentially around the tire under the tread. This construction allows the sidewalls to act independently of the belt and the tread area when forces are applied to the tire. The “independent” action is what allows the sidewalls to readily absorb road irregularities without overstressing the cords. This ‘independent’ action allows two important things to happen (1) the tread of a radial tire remains fully in contact with the road over the entire tread width, and (2) the ply cords and sidewall are able to absorb forces without exerting the twisting force on the beads that are exerted by bias construction.”
Because a radial tire is so flexible, it must have some type of lower sidewall support. Remember the upper third of a radial’s sidewall does all the work. The lower two thirds of the sidewall is supported by the portion of the tire called the Apex. The Apex consists of two stiff, triangular shaped pieces of rubber that extend upward from the bead where the tire sits on the rim. The apex is thickest at the bottom and tapers upwards to a small point. The sole purpose at the apex is stability and support. The apex is a very strong, rigid piece of rubber – so rigid that it becomes the principal component of the run flat tire. How does the apex relate to rim stress? Simple - it transfers road force up to the flex area so that the flexible upper sidewall can do its job of absorbing road forces without “exerting the twisting force on the beads that are exerted by bias constructions.”
Don’t forget about inflation. Radials typically run about 10 psi more than the old bias tires. A poorly inflated radial causes more drag and will create more rim stress. A properly inflated radial with more rigid sidewalls will have less rolling resistance and less
stress on the rim.
The following paragraph is from Old Cars Weekly – 12-6-07 issue. Here’s a condensed version of what someone has written:
“Rims for bias-ply tires and radial tires are made out of different alloys. Rims for bias-ply tires cannot be used on radials. The forces exerted by bias-ply versus radial-ply are different and needs rims made specific for each application. Otherwise there is over flexing leading to rim metal fatigue and breakage. One can tell bias-ply, radial-ply and disc brake rims by their markings.”
I witnessed the transition from bias to radials and I don’t agree with this letter. The letter also says, “ Rims for bias-ply and radial tires are made of different alloys.” Again, I disagree. There were no industry standard markings to identify rims for radial use or rims for bias use, and no alloy changes just to accommodate radial tires.
In summary, all rims are subjected to stress (flex). The stress (flex) point can change its location on the rim (bead seat) depending on many factors – tire size, tire width, inflation, vehicle weight, bias or radial tires. If you have a 50’s or 60’s car, you would be safer with new rims simply because you don’t know the history of the older rims. In the last sentence of the letter someone wrote to Old Cars Weekly he states, “If you cannot find the correct rims you should continue to use bias-ply tires.” This is at best very bad advice, simply because of the safety advantage of radials versus the poor handling characteristics of bias tires. If you are using old rims, you could have a rim failure. The chances are extremely remote, and in my opinion, the cause won’t be whether you’re using radial or bias tires- it’s just an old rim."
Bill Chapman
Diamond Back Classic Tires
*CFR Part 571
Docket #NHTS-030-15400
RIN 2127-A154
nhtsa.com
Old 01-19-2017, 11:11 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Half the stuff that I know about now, I'd have never left the garage... I've beat the **** out of original bias-ply wheels with modern radial tires. Overloaded and hard off-road miles. But, if it's supposedly a no-go, people should be made aware of it so they can make their own decision. I'd have probably purchased new wheels had I read about it back then.
Old 01-20-2017, 06:26 AM
john jamieson's Avatar
john jamieson
john jamieson is offline
I would think that if it were a real issue tire dealers would have stopped installing them on older wheels a long time ago.
Old 01-20-2017, 08:44 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Looks like it's all speculation so far. I'd like to see some actual data regarding how the new vs old wheels are constructed differently. Thicker/better metal? Different bead profile?
Many older wheels lack "safety beads", but otherwise I don't see much difference
Old 01-20-2017, 09:44 AM
KO1960's Avatar
KO1960
KO1960 is offline
I am running tubeless radial tires with tubes on my F250. I have replaced 2 tubes in 10 years with no tire or wheel problems. 16's in the front and 16.5's in the rear. This tire and wheel arrangement was on the truck when I bought it.
Old 01-20-2017, 11:24 PM
The Masked Rider's Avatar
The Masked Rider
The Masked Rider is offline
jmo, but Hogwash. Over the years, I've snapped 2 axles, blown out more tires than I can remember from burn outs, broke a couple drive shafts, and even broke a ring gear once with my 428. And never had problems breaking 50 year old wheels running radials. Guess I'm just lucky.
Old 01-20-2017, 11:26 PM
F-ONE's Avatar
F-ONE
F-ONE is offline
I don't buy it. It's revisionism pure and simple. This is the first I have heard about "weak" bias era tubeless wheels.
The only related issue that has real potential for problems is running a tubeless tire without a tube on a tube only type wheel. That is a different issue.
Old 01-22-2017, 10:29 AM
6t6merc's Avatar
6t6merc
6t6merc is offline
Are you saying that Mr. Chapman's opinion is hogwash?
Old 01-22-2017, 12:33 PM
RangerMercMan's Avatar
RangerMercMan
RangerMercMan is offline
The tires themselves have a date code on them and some people believe there is an associated expiry date on the tires.
Old 01-22-2017, 02:09 PM
Order and Chaos's Avatar
Order and Chaos
Order and Chaos is offline
I'll add my two cents.
I used to work for a BF Goodrich dealer, and have attended multiple training seminars. The idea that a radial tire induces more flex and stress to fatigue the bead lock area of a rim as compared to a bias ply tire due to cornering is at best, utter nonsense, and in straight line driving a radial imparts negligible/no vertical stress to the bead due to the sidewall "radial bulge" above the contact patch. If there was flex occurring at the bead lock meeting point between the rim and tire, the paint/coating on a rim would be worn away and the outer rubber of the bead on the tire would show signs of wear. If anything, radial tires induce less stress on wheels during cornering because of the sidewall flex absorbing some of the lateral force created when the wheels are turned to the left or right, but the mass of the vehicle wants to continue traveling in a straight line.
Old 01-22-2017, 11:21 PM
F-ONE's Avatar
F-ONE
F-ONE is offline
No. He agrees with Mr Chapman's conclusion as do I that bias era wheels are safe as long as they are in good condition.
It's the argument that Mr. Chapman posts before his conclusion that we see as "hogwash".
Old 01-23-2017, 07:24 AM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Same here.
Old 01-23-2017, 07:50 AM
BarnieTrk's Avatar
BarnieTrk
BarnieTrk is offline
I've never done it, but is there a visible difference in the wheel/rim construction between a wheel intended for a tubeless tire versus a tubed tire - other than the installation of a valve stem?
BarnieTrk
Old 01-23-2017, 08:36 AM
6t6merc's Avatar
6t6merc
6t6merc is offline
An interesting question, Barnie. I always thought the tube was required because those wheel types - even a one-piece wheel - are not airtight but there might be more to it as you suggest.
Eric
Old 01-23-2017, 10:27 AM
Order and Chaos
A typical steel rim is made from two pieces in to one, the stamped center disk, and the rolled outer barrel joined together by a mix of welding styles after being press fit together. I could reasonably see a steel rim being tube type or tubeless based upon the quality of the welding and finish. A porous versus airtight weld, how smooth the weld is finished, etc.
It pretty much comes down to if the rim is marked "tube type" or "tubeless", go with what it says. In the case of a wheel with no designation marked on it, as long as a rim has the bead lock bulge rings built in to the barrel (the pop you hear when a tire is initially inflated) tubeless tires should be okay.
Other than that, if you're running an inner tube with a radial tire, make sure it's a tube for radials. Inner tubes for bias and bias belted tires aren't made to handle the sidewall flex of a radial tire.
Quick Reply: Radials on wheels meant for 60's bias tires.
