How to not chew up tow hooks?
I bought a 17 XLT work truck and will be taking delivery tomorrow. We have had more snow this winter than any winter I remember. Sooner or later I am going to need to use the tow hooks to either pull someone out or get pulled out myself. Since they are a closed hooks, what can I use on them so they don't get chewed up? I am sure I could use a tow rope and and double back through the loop but in the past I have had a very difficult time removing the rope after doing this. What do you guys do?
Received 6,680 Likes
on
Old fire hose outer liner slipped over the shackle would work. Just cut to the length needed. I use this over my tie straps so they don't get cut on the trailers. Just contact your local fire department and ask for a small fire hose that they are discarding. One length will last several friends a lifetime.
Saw these at my local H.D. The other day. Good price. I use these without the insulator, not to wooried about them like mentioned earlier. But to each his own.
Husky 3/4 in. Bow Shackle 54535 at The Home Depot - Mobile
I use a standard steel shackle and hook my tow straps to that. I've pulled out a stuck tractor on my 2015 Lariat with chromed tow hooks - no appreciable markings on the chrome. I've pulled out a stuck equipment trailer with the black hooks which included a lot of hard yanking in reverse, in 4x4. No appreciable markings on those, either. Have yet to try the 2017 hooks, but they seem similar. I was impressed how well the finish seems to hold up.
If your hooks are black, just repaint. If they are chrome, might be harder if they really got dinged up.
I thought you said it was a work truck? Is it a real work truck or a "hey mister tax man look at my new work truck" kind of work truck? My guess is you should have years of use on those tow hooks before you see any wear from a tow strap. I can see chains doing a number on them but I am guessing you should be good bro. I wouldn't stress it.
