1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear Brake hanging up
Old 01-15-2017, 06:21 PM
svastano's Avatar
svastano
svastano is offline
Group, I keep having this problem with my 02 Superduty. The rear brakes keep locking up and smoke the pads. The truck is not driven much so that is most of the issues. it has less than 63,000 miles on it. Mostly only driven in the winter with the salt and crud so rust is a problem. What is your advice on changing so that I can get more than a year without having to do it all over again. I am going to get new calipers and the brake kit. Should I get e-brake stuff too?
Thanks in advance.
Sam
Old 01-15-2017, 06:27 PM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
Stop driving in winter salt... no other way..
I have lost several very good vehicles to road salt..
I live in the Snow Belt of N.E. Ohio... 5 months of it.
Old 01-16-2017, 09:23 AM
ashleyroachclip's Avatar
ashleyroachclip
ashleyroachclip is offline
The calipers have a plastic piston , that is a known problem .
Just replace the calipers , pads .
With that few of miles , I doubt you need to replace the parking brake shoes .
Old 01-16-2017, 10:27 AM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
NewEnglandHerdsman is offline
One sometimes overlooked area to check is the seats in the caliper brackets where the pads sit. There is a stainless steel clip between the ears on the pads and the seat area - rust can build up between the clip and the seat, causing the pads to stick. When replacing pads make sure to clean this area up - some even advise a light touch with a grinder, but make it real light so you don't cause a rattle. Apply a bit of good anti-seize compound there as well. There's some copper based anti seize that I think is recommended for this.
Old 01-16-2017, 04:36 PM
ligito's Avatar
ligito
ligito is offline
Try to limit use of the E brake, in winter weather.
They can freeze and cause issues.
Old 01-16-2017, 06:12 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
I respectfully disagree that using the ebrakes in the winter isnt a good idea...here me out. Yes on much earlier vehicles this is a very true statement. Looks like you have a stable of older ones for sure. Im speaking specifically about older vehicles, before the weather proof coated and sheathed cables made their debut. This pretty much eliminated the draw-in action of road contaminate each time the ebrake was applied thus causing the cables to seize. Been there done that. Today not using the ebrake will enhance seizure somewhat as the hardware will rust up. Inspect the ebrakes. Yours may have the same issue as most of the rear disc braked E & F series trucks have had, cheap under-designed junk backing plates. Likely chineasium. The ebrake shoe anchor pins pull through the plate then the shoes and their hardware get ground up nicely and can cause brake seizure. Especially on a salted sparsely driven vehicle...been there done that on both my 08 and fairly clean and rust free 11...sadly.
Great advice from NewEngland, an often overlooked area when doing a brake job. The pads need to float a little bit otherwise they will hang up or not retract. Inspect the 15 year old rubber brake lines. They can delaminate internally and can cause a one-way-valve effect and actually hold pressure on the caliper pistons for a period of time (or wheel cylinders if you have drums). Cheap insurance to replace rubber lines every 10 years. On a vehicle like yours that sits you should be bleeding the brake system every 2-3 years or so. In fact everyone should be doing this. Dont replace anything until you do a complete bleed as you'll be pumping contaminated fluid into new calipers and lines.
"What is your advice on changing so that I can get more than a year without having to do it all over again." Buy top quality parts including coated rotors, painted/powder coated calipers. Then drive the thing to full op temp once a month. (20 miles). Park in a garage. Rust proof the chassis & body(google Krown).
"I am going to get new calipers and the brake kit. Should I get e-brake stuff too?" Ive learned over the past 40+ years of wrenching to buy everything then take back what you dont use. Less headache, saves several frustrated greasy traffic ridden trips to the parts store.
Quality brake part vendors...Wagner, Hawk, Power Stop, Ford OEM MotorCraft....everything else has been brought over on a slow boat and wold last. Do your home work as each of the above has their pluses n minuses.
Old 01-16-2017, 06:42 PM
svastano's Avatar
svastano
svastano is offline
Thanks for the good info. I do use the e-brake all the time so I will take a look at it when I am in there. It is probably just the caliper but who knows. I do oil the underneath so there is very little rust on a 14 year old truck.
Old 01-18-2017, 06:47 PM
droldsmorland
Oiling the undercarriage nicely done sir!
cw_mi
05-01-2013 10:22 AM
j.grif
2004 - 2008 F150
11-08-2011 10:23 PM
dogerbrown1
10-23-2011 11:31 PM
week0019
2004 - 2008 F150
12-02-2008 05:43 PM
billj6
1983 - 2012 Ranger & B-Series
01-03-2005 09:38 PM
Quick Reply: Rear Brake hanging up
