Dip stick tube pulled out?
So while I was doing the GP change, I of course had to unbolt the dipstick tube, and move it out of the way to pull the valve cover.
Well whilst buttoning everything back up, I realized the the bottom of the tube was still loose, crawled under and saw it was hanging there loose.
I pushed it back into the hole, but it seems like it can pull back out easily still, and probably I assume leak oil as well.
Am I missing something?
Should be a special o ring down there to seal and hold in place. Blue, beveled, maybe still in your driveway. If not, Bob can hook you up.
Diesel O Rings
Diesel O Rings
FordMattVan
07-06-2019 07:05 AM
nlemerise
05-29-2012 11:53 AM
