2018 Ford F150 Diesel just announced!
What horsepower and torque specs do you folks expect for a Ford 3.0L V6 diesel in the MY18 F150?
185hp@3,000rpm, 350 lbft@1,500 3.2L I5 PSDiesel (Ford Transit
254hp@3,750rpm, 443 lbft@1,750 3.0L V6 Td6 (MY17 Range Rover diesel
365hp@5,000rpm, 420 lbft@2,250 3.5L V6 EcoBoost (F150/Expedition
375hp@5,000rpm, 470 lbft@2,500 3.5L V6 EcoBoost 2nd Gen (MY17 F150
240hp@3,600rpm, 420 lbft@2,000 3.0L V6 EcoDiesel (Ram 1500
310hp@3,200rpm, 555 lbft@1,600 5.0L V8 Diesel (Titan XD
while this is nice I figured they would go with the 3.2 since the emissions groundwork is already there? OR is this the CGI block from Dagenham that they were working on several years ago? IF it is the Dagenham engine then the top spec that is being currently used in the Jag and Land Rover are running at 271 hp and 440 ft lbs torque. Appears to be using common rail and twin turbos...figure they may drop the twin snails to one and drop the HP down a shade so they'd have wiggle room when Dodge starts bumping their numbers to compete.
as an aside...I'd REALLY like to see some stuff on the new Ranger.
D
D
185hp@3,000rpm, 350 lbft@1,500 3.2L I5 PSDiesel (Transit
375hp@5,000rpm, 470 lbft@2,500 3.5L V6 EcoBoost 2nd Gen (Raptor
Apparently Ford is trying to resolve some of the downside of the 3.5L EcoBoost v6 with Direct Injection, by adding intake Port fuel injectors, to deliver some fuel to the backsides of the intake valves. Would we call this the Gen 3? This is done on Direct Injection motors from other manufacturers
D
D
When the hybrid comes out, it'll have better city numbers mpg wise over the diesel, but the diesel will still shine on highway runs because the hybrid can't use Regen braking as much. Man it's a great time to be a Ford and truck lover, we are spoiled by the choices we now have.
Next few years will be interesting. Ford usually waits a couple more years before a redesign... Notable exception was the 2004-2008 model years. Before it was 97-03 and 09-14. Now it's 15-17. Wonder if the changes will do anything the the aerodynamics of the trucks? Guessing 2020 will be another redesign to add the hybrid to the mix.
I'd expect mid-20's for fuel economy and 8-9,000 lbs of towing capacity. Right in the sweet spot for what most use their trucks for, as long as the sale price is right.
I think that's unlikely. It's probably going to follow a similar path to the EcoDiesel Ram 1500. It typically takes greater displacement and boost for a diesel engine to make power to an equivalent gas engine. It's likely the output numbers will be similar to what you're seeing in the Range Rover at 254/443. That's substantially less than the 375/470 that the 3.5L EB makes.
I'm not in line for a little compression ignition truck. Smelling like you slathered on eau du diesel cologne every time you fill up the truck. Having to carry gloves in the truck to keep the grime from the pump off your hands. Searching for a "good" station when traveling hoping to get decent fuel. Having to wait for one of the couple of diesel pumps to open while some gasser decides to use the combination gas/diesel pumps when 8 or 10 gas only pumps are open. Then have something that won't do what it should..... tow performance. Dealing with the regen problems (not finishing on short trips, economy down the tubes when happening). Nah...
My guess, 8-10k range, likely in the middle. With the new Gen2 3.5EB just released now, it will be the tow king. Ford obviously had the little diesel in the plans when they were working on the new 3.5 EB. I see the new diesel for maximum mpg to meet what ever mark the government requires. Having announced the new 3.3 NA, and the injected 5.0, I'm not sure where this leaves the 2.7?
