Won't start after pressure wash
While trying to pin point a oil leak I was washing underneath not sprayin all in the motor and go to start when I finished and everything works wait to start light comes on...goes off and won't fire up...also I think to oil temp light doesn't go off when key is turned over and not reading any oil pressure...help!
Your going to have to give us a little more to go on like Vehicle, year, model, engine ( v8 v6 4.6, 5.4 6.2. 6.8, 6.0, 6.4, 6.7 ) Gas or diesel etc
That will help in giving you some advice. My one suggestion would be to take a leaf blower or if you have an air compressor and try and blow as much sitting water off the engine in place where you see a lot of wetness, especially around the spark plug wells. Water loves to sit in the wells, blow them out and make sure your battery connections are tights and not corroded
The ones I find curious are the guys who never come back and say what the solution was to get their trucks back up and running, your always curious to hear what solved the problem in hopes it might help others.
Have to wait to see if the Op posts back now
That was also great advice! Once in a very long time, all lightly spray dirty areas on top of my engine with simple green, let it soak in for 5ish minutes and spray off. When I say spray off I literally mean mist off gently, while avoiding any electronic connections. Then use rags to wipe down any remaining dirty areas.
Fuse Box, computer connection point, any areas were wires are exposed coming to a connector I always wrap them up and put some tape on them after I am done washing then it is either some air from the compressor or the leaf blower and start to dry the engine off still leaving those areas wrapped off, after I take a little spray bottle and clean those areas with a clean cloth and then dry them off with a different cloth
too many horror stories about guys gong all commando with the pressure washer and soaking everything in sight and then wondering why their trucks are not starting
Ironic you guys mention that. My daughter and her b/f asked if I would use a pressure washer if they bought me one for x-mas, I told them,only on the vinyl siding of the house,never my vehicles or bike. I have seen to many problems caused by those things...good ole garden hose and nozzle for me.
I bough my dad one for his birthday to make it easier to wash his truck and what not, lol.. say it uses too much water, so he still uses the bucket and garden hose and a brush, but loves it for the windows on the second floor on the house
I keep my engine compartment clean all the time. I wipe it down every other truck wash. Never use a pressure washer in there though. If you keep it clean under the hood it isn't that hard to do. If you need to use a hose and simple green which i have also done in the past just use your shop vac to blow off the water. never usw high pressure to rinse off the soap.
You guys are paranoid.
I use a pressure washer on every inch of my truck , and every rig I work on .
I refuse to work on greasy nasty stuff .
So clean them up , blow them off , and start them .
Vehicles are designed to operate in many extreme conditions these days ,and most if not all of the electrical connectors have a weather pack connector of some type .
There are some components,that I am sure that if you just blast on them , will get wet .
A can of WD40 ,can be your friend with wet connections should you have them .
I used to do a lot of mudding with my old 72 F250 .
Was great in the mountains and mud , but sometimes , the distributor would take a bath , and the old boy would take on water or steam in the cap .
Pop it off, spray wd40 , put it back, same with the plug wires , and be on my way .
Obviously not as technical as today's vehicles , but still a product that will get you up and running , should you need .
funkoptimus
13
02-12-2005 02:16 PM
okie 64
08-02-2002 08:27 PM
