'89 F350 Tilt Wheel
Old 01-07-2017, 03:04 PM
Evan Darbous's Avatar
Evan Darbous
Evan Darbous is offline
'89 F350 Tilt Wheel
Hey all, I have an 89 f350 and the wheel tilt mechanism has failed. It will adjust and settle into positions as it should, but once pressure is put on the steering wheel it falls all the way down. I'm gonna start tearing into it soon, but don't know a whole bunch about steering columns and hope someone has some information about these mechanisms I should know about, thanks
-evan
Old 01-07-2017, 03:19 PM
jplinville's Avatar
jplinville
jplinville is offline
'89 F350 Tilt Wheel
If I were you, I'd start looking for a replacement column, instead. I've had mine apart before. It's just easier to replace the whole column, if one is available to you.
Old 01-07-2017, 03:50 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Evan Darbous
I have an 89 f350. The wheel tilt mechanism has failed. It operates as it should and goes up and down and even stays in place, but when pressure is put on the steering wheel it immediately falls as low as it can go
Does your truck have A/T or M/T? The tilt wheel parts are the same, but I want to post the correct pic.
Old 01-07-2017, 04:50 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,575 Likes on 1,286 Posts
Moved from Large Truck.
Old 01-07-2017, 07:14 PM
donnor's Avatar
donnor
donnor is offline
"TILT!"
It has been a long time since I had a tilt column of this type apart but I believe there are two small coil springs; one each at about the 4 and 8 o'clock positions which cause the driver end of the column to rise to the top position when the release lever is pushed forward. What you are describing sounds like at least one or perhaps both of these springs have failed/broken. While it is possible to rebuild these columns (I have done so on a couple) an easier remedy would probably be to just replace the column. I believe eligible candidate donors would be any F-Series or Bronco from 1980 through 1991. Choose automatic or manual transmission version to match yours. If you choose the rebuild route your candidate list would include a host of 1970s Ford, Mercury, and Lincoln cars; though unfortunately most of those have long since been crushed, shredded, and shipped to China.
Old 01-08-2017, 10:18 AM
NumberDummy
Misc: 1965/80 Passenger Cars; 1978/91 F100/350, Bronco & Econoline: Tilt wheel operated by pressing the T/S handle forward.
Look at 3B661 in parts catalog pic (A/T shown, M/T is similar). This is the tilt wheel locking lever, when its serrations wear down, the wheel will no longer lock in place.
E2TZ-3B661-A (replaced D1AZ-3D661-A) / Obsolete ~ No one has any NOS
Applications: 1971/80 FoMoCo Passenger Cars; 1978/91 F100/350, Bronco & Econoline.
Old 01-08-2017, 08:32 PM
Evan Darbous
It is an automatic. I have pulled the column apart and found he mechanisms that operate the tilt. The spring's are fine, as I could not see how they would lose tension because the the downward motion would not over stretch either of them. I pulled the latch out and it does not look cracked worn or broken as I suspected it would be. But while testing the whole operation I noticed the pin that slides into the serrated grooves of the latch spins. Through my observation it seems as if there is just a slight bit of play in the latch (I would assume just to simply allow the rod to seat in the grooves easily. Not excessive play) but I'm under the assumption that the spinning rod is allowing the latch to continue moving and falling out of place instead of firmly seating itself. I guess my general question is, should the rod the hold's the latch in place supposed to spin inside it's housing like it is? Because if it's not I'd rather epoxy it tight in place rather than buying a column
Last edited by Fomoko1; 01-08-2017 at 10:41 PM. Reason: Language that`s not allowed on FTE!
katzklaw
01-19-2016 12:40 PM
bulletsneverlie
16
08-21-2012 12:55 PM
96sherm
40
09-26-2008 08:08 AM
hammerdn
01-12-2004 11:27 PM
Quick Reply: '89 F350 Tilt Wheel
