1995 PSD cranky but no starty...
I am sure this has been answered 1000 times but we all have to get our turn...right? Been a lurker here off an on for a while, love it!
Working with a 1995 F350 7.3 PSD Auto 226,xxx miles
Truck is not my daily driver anymore just a once in a while but decided to drive it yesterday to work. Cold start this morning and worked just fine then to visit mom and dad now won't start (sat about an hour). Has gotten colder here in Ohio but the truck was still warm when tried to start it up. Wait light comes on, seems to crank faster than normal, tach is not moving so I replaced to Cam Sensor with the Navistar version (replaced it around 175,xxx miles too). Still does not start, tach does not move and no smoke. All fuses look good and the wiring to the cam sensor appears intact. Nothing else significant while driving it, fired just fine around 19*this am not plugged in and drove 5 miles here. Any thoughts? Hate to think the PCM... Any help is greatly appreciated (especially that which I have already used to get me to this point)
Thanks Chad
Thanks Chad
Have you tried following the no start flow chart?
Any way to monitor data on your truck? How is your oil level?
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Finally got the fuel pressure checked (thanks autozone tool rental) and builds up to 40 or so psi while cranking the engine. ICP has power.
Checking the IPR is on the list for tomorrow. Test the injectors. Then going to steal a friends IDM to try if all is well there.
Found some good info here: » 7.3L Powerstroke Tech Info
Also got some good schematics from the library.
