Door window lift channel rubber seal
Is this any thing specific to the vehicle or can any work glass installation?
I bought new window materials from DC to replace my rotten window channels, anti-rattle kit, spring etc but didn't see this on their site.
A close up of it
Can this stuff be bought locally? You need it for the window pane to stay in the lift channel.
A close up of it
Yes, same stuff that holds the vent window into its retainer.
I did an Advanced Search on
Username: NumberDummy
Keywords: glass tape
Came up with these 13 threads where he has mentioned it before. Should be something your local glass shop has, assuming you have a local glass shop. It can also be ordered online. It comes in different widths so make sure you get something wide enough to hold, but not too wide that it sticks out a bunch on the sides.
Ford Truck Enthusiasts Forums - Search Results
I hope that is somewhat helpful.
Chad
Chad
Thanks. Didn't know it was called tape. It looked like a preformed seal.
Ran down to a glass shop and talked to them. The owner gave me a few feet of butl rubber for free. Said if it didn't work then glue in with 3m stuff. Also mentioned that if I ever got a broken window that heat would help release the glass from the glue. .
I'm going to try the butl rubber strips in the AM.
art vandolay
08-25-2017 11:34 AM
sunbird79
13
12-31-2011 05:21 PM
Flathead 51
02-20-2010 12:48 PM
