Anyone have a 4 inch highboy lift kit OR a coupon for 4wheelonline ?
Looking to purchase a complete 4 inch lift kit with all 4 leaf springs and shocks and hardware for a 77 highboy......
Anyone?
OR
if not does anyone have a coupon code for 4wheelonline.com?
They have a complete kit with shocks for 1296 shipped which is decent but maybe i can save a few bucks since my Dana 60 front axle rebuild kit cost me an arm and a leg...
Anyone?
OR
Rocky Mountain has free shipping. Suspension lift kits - Ford F250
Personally I will NOT use Rough Country again.
Make sure you get the 2 1/4" wide rear springs. And new u bolts front and rear make the swap way easier. Those fine thread u bolts usually get the threads ate up taking the nuts off or they just snap, nuts freeze up or you end up torching them off.
If you just have to reuse them (highly NOT recommended though) make sure the u bolt threads are VERY clean and get new nuts.
Also might as well get Energy Suspension poly bushings and remember that you will probably need the other bushing set for the rear short shackle.
And you might have to reuse the rear OEM block. Atlas gives you the option to delete it.
OEM Ford Pick Up Truck OEM Replacment Springs Atlas SuspensionAtlas Spring Company
1973-1979 F250//F350 4x4 Atlas SuspensionAtlas Spring Company
