Sport mode
#31
Here's the page from the owner's manual...seems interesting to me that the manual has no mention of 'sport' mode but it is clear from the table that the double press of the traction control button reduces sensitivity of the traction control system and the stability control system. Does that make the truck handle in a more sporty way?
Also, I don't think this should be confused with the sport mode of the F150s since this does not affect transmission shift points.
#32
Thanks for the reminder from the manual, and yes, only pushed once and so the traction control and roll stability were still reducing engine RPM. I will need to go with the longer on the TC button for the next time. I can see where these different options would defiantly have their uses as the diesel is so torquey it's nuts.
#35
#37
#38
#39
#41
#42
I press and hold the button for 6 seconds on my truck every single time I start it up. I don't want that stupid crap effecting the way I drive. I was so mad with my 2016 Ram 3500, because you could not turn it off at all!
I'm really tempted to pull the rear ABS sensors or fuse to permanently get rid of it...
#43
#45
Traded my 2018 Ford Raptor in May for my 2018 F350 Platinum Diesel. Had a Pedal Commander in the Raptor and made a world of difference in throttle response and Turbo Lag. I kept it when i traded the Raptor and turns out its the same part# for the F350. Not quite as much improvement as the Raptor but does make a very noticeable difference in throttle response. I consider this sport mode and would actually purchase one again. Driving the truck in stock mode seems almost dangerous!
If you get a chance, try one, you'll like it!
