1Legs 2001 F250 CCSB 4wd/Auto build thread
#47
#48
So I got a new/rebuilt stock turbo center section from a local turbo shop called pure turbo, I only have 2 day of driving on this and so far so good. I also bought all the parts need to rebuild the fuel bowl and fuel lines from Riff Raff. I also add the FRX and CVD high flow fitting. I also did a oil change and added Hot Shot Stiction Eliminator.
I also painted the Turbo inlet housing and spider international red and header wrapped the hot side pipe. I want to wrap the cold side also.
I have only had 2 day of running and so far power if back to normal, the engine seems to be much quieter and smoother. Start up in the morning is easy and quick note I live in socal.
Next up are the up-pipes and looking for some 2015 seats.
#49
Yesterday I did the "Red Tube Mod" and the Harbor Freght "DIY Boost Fooler Mod". Very happy with the increase in throttle response. It isn't crazy new power just seems to have a little more get up and go when you give it the skinny pedel. I can't wait to ee how it does on the highway.
Still no plans for a tuner or bigger injectors I don't need that power.
Todo list is getting longer (not in order)
Up Pipes
Full trans flush and filter change
Raptor coat the roof "White"
Raptor coat the sides to cover the gold "White"
Repaint the hood (peeling paint)
Up Pipes
#50
I understand your desire to keep the OEM AD injectors, I am in the same boat.
Although, I would like to make a suggestion that you re-evaluate your "no tuner" thoughts. A Hydra tuner can provide so much more than just "power". Take a look around wide an open mind on the tuner and don't focus on the "more power" aspect.
If you still decide to keep the programming OEM, then more power to you as we all have different goals and inspiration for our 7.3L.
#51
I have given some thought to a tuner to help with transmission shifting. I'm convinced that I will be doing a trans rebuild in the near future. In about 6 months my towing opportunity will greatly increase. The truck in stock form should tow easily what I plan to tow (less then 8000lbs). I suspect injectors will also come in the future and at that point why wouldn't you step up to stage 1s and at that point a tune will be need..
#52
When my 255,000 mile injectors finally give up, I will be getting new Alliant AD injectors. I tow 12,000 lbs cross country and get plenty of power out of tired AD injectors, advanced turbo and a Hydra tuner.
#53
#54
I'm hoping I don't have to do injectors anytime soon, I will for sure do my research first and get advice. Truck is at around 293000 and as long as I keep the oil changed and use some sticktion elimination additive I don't have any issues with start-up and runs smooth. Don't worry no plans to do any injectors without input form the FTE crew. Thanks again guys,
#55
#57
Truck is running great, I'm trying to get through the current tank of fuel that started this recent repair. Currently at 1/4 tank.
Installed a Bilstein front steering dampener part # 24-158848. Looks good haven't driven yet, replaced a worn out pro comps. Guy a 4wd part tried to up sale me to a dual shock version. Told him it was a stock truck with stock size tires. He said I would be back because it will do nothing but pull to one side. Then asked if I ever install 1 before, I said a few.
Ordered new front shocks, Bilstein 5100 part# 33-187297 off Amazon should be here Wednesday, Truck has pro comp 2" level spring on the front that are worn out. Looking into some custom springs for the front.
I will be going on a 300 mile round trip next weekend. So the plan this weekend is to do a transmission flush and front diff gear oil change. For trans fluid I'm going with Valvoline max life. Front diff is getting store brand Synthetic.
I was able to finally adjust my speedometer using the Forscan program.
#58
Got the transmission flushed and front diff fluid changed yesterday. While I had the transmission pan off to change the filter I torqued all the valve body bolts.I would say all the bolt were loose a couple took more then 1 turn to torque. I also removed and sold the ladder rack and toolbox.
Went on a 50 mile test drive up the freeway with a couple of good climbs. Transmission temps never got over 145 and the shifting seems to be greatly improved. While climbing 1 hill I got on it pretty hard and that is when the transmission temp climbed to 145. after coming over the top I slowed down to 65mph and the temps dropped down to about 141 within a few minutes.I'm not sure how accurate the torque pro app is but it said I was getting 24mpg
#59
Truck ran great on my trip this weekend. I was not towing or hauling anything just driving up to El Miarge lake bed to crew for friends land speed car. it was around 278 round trip and didn't quite use a half tank guess is it got around 15 gallon. So that is around 18mpg, not bad as I drove 75+ all the way there.
Tranmission got to around 169 in traffic.
#60
Hydra tuner from RiffRaff Installed 10/30/2019, So far the 65 sipper tune is the best DD mode.Would prefer a 40 hp sipper. Transmission shifts much better.
Installed a 6637 filter using my K&N intake. Seems to work together fine. No noticeable sound or performance noticed on a drive through town.I want to build a custom box to enclose the filter.
