My 68 Lwb to Swb project build
Old 12-30-2016, 05:12 PM
Jmiller68's Avatar
Jmiller68
Jmiller68 is offline
My project has started prior to seeing this forum.
The build goal is to convert my dads 68 ranger long bed to a short bed.
I will definitely need some help along the way.
Here some pics so far
Old 12-30-2016, 06:50 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
Nice looking truck. Was the grille in it replaced at some point? Reason why I ask is because the grille in that truck is from a '69 Ranger.
I see the F100 has already been converted to front discs.
Old 12-30-2016, 08:13 PM
Jmiller68's Avatar
Jmiller68
I'm not sure about that, I do know it's a 68 for sure. I will check into grill. There is no telling what my dad did to it over the years. The truck has been in my family since 72'
Old 12-30-2016, 08:17 PM
Jmiller68's Avatar
Jmiller68
More pictures, this is the current state
Old 12-30-2016, 11:38 PM
dman2008's Avatar
dman2008
dman2008 is offline
Looking forward to your build. Is the plan to use the frame beside it and get a Short box or just cut down the long box?
D
Old 12-31-2016, 03:16 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
D
I had the same question.
Old 12-31-2016, 03:18 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
That Cab stand is the best I've seen.
Old 12-31-2016, 06:17 AM
Jmiller68's Avatar
Jmiller68
I bought the short bed along with frame. The short frame is in some of the pictures. I had it blasted and epoxy painted. Was going to paint frame myself but couldn't pass up the deal the sand blast company offered. I'm not doing the body or paint work either. I don't have the means or ability to be honest. I'm fortunate this truck spent most of its life in Texas. I moved to the east coast in 2004 and brought truck up in 2005. I rebuilt the engine, trans and put front discs on in 2012. Now I'm diving back in to make more changes
Old 12-31-2016, 06:21 AM
Jmiller68's Avatar
Jmiller68
The cab stand took a while to build. I added gussets for support the other night. I built it a little over kill, so I could transfer cab on trailer safely to paint shop.
Old 12-31-2016, 07:19 AM
cstoyer's Avatar
cstoyer
cstoyer is offline
I built one very similar to from metal tubing and locking casters for my cab and it does indeed make it easy to move around. Especially when I took it to have it Media Blasted.
Looks like a good start for your build.
cstoyer
Old 12-31-2016, 08:16 AM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Subscribed. Looking forward to see you progress. Everything looks nice and clean.
Old 01-02-2017, 03:12 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Me too. Sub'd as well. Looking forward to watching your build. Hey Brian, pass the popcorn!
Old 01-14-2017, 06:05 AM
Jmiller68's Avatar
Jmiller68
Cab and doors are off to paint and body shop. I am going to replace dash pad, any recommendations on who to buy from? Dennis carpenter? Made a little progress on old frame, hopefully to have it out of shop this weekend.
Old 01-14-2017, 08:17 AM
Brian1971f100
Looks good so far, Your not going to be able to use your spring packs. The ones you have on the original frame are ez-ride shackles, they should measure 56" from center to center. You will need standard spring pack shackles. The springs will measure 52" center to center.
Here is a link to information on springs if you need it. Leaf Springs 1942 - 1972 Ford F100
Old 01-14-2017, 08:44 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
EZ Ride?
FlexoMatic!
Quick Reply: My 68 Lwb to Swb project build
