2001 Ford Escape hood latch - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 12-29-2016, 09:38 PM
Kayleen Jenkins's Avatar
Kayleen Jenkins
Kayleen Jenkins is offline
Kayleen Jenkins is starting off with a positive reputation.
Arrow 2001 Ford Escape hood latch
Hey all!
I just purchased a used 2001 Ford Escape XLS, its pretty good and every issue I've found I can fix myself, however the hood release inside the car doesn't work. I can easily lift the hood open, just need to lift the latch under the hood and its up. I feel pressure on it when I use the in-car release like normal, but it never pops open. The front is banged up a bit, but nothing too bad. I think the previous owner ran into a wooden fence post or something on a ranch. Does anyone know what I can check to get it to not open easily without having to get in the car and unlock it? Or would I need to consider getting another hood?
So basically I want to make the in-car hood release work again, so the passerby can't just pop the hood open and take anything from under it.
I appreciate the help!
Last edited by Kayleen Jenkins; 12-29-2016 at 09:50 PM. Reason: added more information.
Old 12-30-2016, 06:13 AM
simonsi's Avatar
simonsi
simonsi is offline
simonsi is starting off with a positive reputation.
You shouldnt drive with only the safety catch working - the hood can fly up onto the windscreen while driving. The safety catch doesnt even hold the hood fully closed...
Without a better description or seeing what the problem is its difficult to suggest what needs fixing but have you lifted the hood 12in and dropped it, does it then latch?
If the front has been impacted at all then the latch may be out of line a little or a large amount, impossible to tell over the internet...
Old 12-30-2016, 06:18 AM
Kayleen Jenkins
I do need to pry the hood open, I think easily was the wrong word. I'll get some pictures when I get off work, it does shut like normal and the latch under the hood always needs to be lifted to open it all the way.
But I'll get some pictures after work this morning
Old 12-31-2016, 09:11 AM
got2bjoester
got2bjoester is offline
got2bjoester is gaining momentum as a positive member of FTE.
FWIW:
My 2002 had a similar issue - it ends up the bottom of the support that goes from the latch down to the frame at the bottom of the radiator was rusted through and out leaving the support hanging. When the hood closed to the point of almost latching, the bottom of the support would swing enough to prevent the latch from ever doing its job. This left the hood only closed by the safety catch, much like yours. I'm not saying you have the same issue, but it's worth a look.
Open the hood and see if the support can be moved . My fix until we traded it for a newer one was to reach under the front anf hold the support while closing the hood. It didn't take much, but it wouldn't latch on its own when the bottom of the support was allowed to move.
Old 12-31-2016, 10:29 AM
Kayleen Jenkins
Thanks for the tip, I'll check it out once it gets above freezing The safety latch does catch every time, I'll see if i see something else under there.
Here's a picture of the damage on the front (no other dings on the hood, just where its pictured) , not very bad near the hood like I said. And its just frost along the top.
(Regular link in case it doesn't work) Imgur: The most awesome images on the Internet
Old 12-31-2016, 10:48 PM
got2bjoester
Could also be the alignment of the latch itself.
Old 01-01-2017, 12:01 AM
simonsi's Avatar
simonsi
simonsi is offline
Doesn't look like the hood is shutting fully to me.
Old 01-01-2017, 09:16 AM
got2bjoester
Based on The single photo alone, the damage shown could mean the upper radiator strut has moved slightly. This would change the alignment of the latch and could easily make the hood fail to close properly. Any body mechanic should be able to properly diagnose this and come up with the right fix.
Old 01-02-2017, 07:08 PM
scott91370
scott91370 is offline
scott91370 has a good reputation on FTE.scott91370 has a good reputation on FTE.
I'm confused...
The will or will not close all the way?
I read as this if it does close and once closed the hood release i sode the cabin does not work.
tip49
29
07-13-2017 07:31 PM
ExxWhy
12-15-2016 05:32 PM
TexasRebel
1999 to 2016 Super Duty
16
09-09-2016 08:54 AM
GreenMM
1968-2013 Full Size Vans
20
08-14-2016 12:41 AM
GreatNorthWoods
15
02-29-2016 07:54 PM
Quick Reply: 2001 Ford Escape hood latch
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
