Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Hissing Brakes
Old 01-03-2017, 05:16 PM
simonsi's Avatar
simonsi
simonsi is offline
Hissing Brakes
Just got my first Tribute (2001), has the hissing brakes issue but surprised to find 95% of the noise could be avoided by un-hooking the booster boot inside the footwell.
Looks like the noise comes on as the boot becomes less tight on the booster in service allowing the air inflow to hiss/whistle through the boot join onto the booster.
Step 2 will be to see if tie-wrapping the boot in place also reduces the noise (it should do)...
Much easier/better/less $$$ than replacing the booster...
FYI the boot has a vent system with a foam filter around the pedal pushrod end so it is designed/expected to flow air through it, it seems it only hisses when the air can pass through the boot-to-booster join...
BigSexy78
01-17-2017 07:03 PM
azfordf100man
10-16-2007 12:12 PM
Big Red
11-22-2005 07:07 AM
redtruck
03-27-2001 02:45 PM
Quick Reply: Hissing Brakes
