4R100 - Ticking Sounds
I've got an E350 with a 4R100. Fluid looks good, shifts and drives great but has an erratic ticking sound while in park. Goes away in gear. Using a stethoscope on the top side of the transmission, it is loudest just behind the case vent. Kind of sounds like a marble bouncing around. Anything to worry about?
A common problem on the 4R100 is the coast clutch snap ring coming out of the groove. This can cause the noise you're hearing, but if it's come out you won't have engine braking. A cracked flex plate is a possibility.
dangerous_mechanic
03-21-2021 05:24 PM
catto95
07-13-2019 10:38 AM
jay42782
46
08-01-2009 05:22 AM
