08 Warbling sound upon shut down
I've got an 08 srw f350 quad cab with 113k on her. DPF delete.
My wife drives it. I maintain it. When she rolled into the garage the other day, she shut it down and I heard a slow rotational "Warbling" sound as if the fan was slowing down to a stop.
Popped the hood and inspected everything. It's levels are all good and clean, the mechanical wiggle test proved nothing to be loose.
I had her fire it up and shut it down with my head and eyes nervously watching and it is matched to the fan slowing to a stop.
I've read a lot on this forum and I'm leaning toward a fan clutch problem although I can spin it at will and not get the noise, or am I looking at possibly a water pump issue.
The noise matches the fan rotational speed as it slows and as far as I know, the water pump is not rotating if the engine has already shut down.
All gauges and lights are normal.
About the only real way to see if it is the fan, is to remove it and see if the warble disappears after shut down.
Make sense or should I be looking at something else??
Highest regards.
Denny
Highest regards.
Denny
Really! I assume those were to mark the depth for traffic. That picture you see in my avitar is the Ferry at Augusta, KY going across the Ohio River to Ohio.
Brada. Any coolant leak history, how is your temp gauge?
I can't nail this and I ain't a spring chicken, but it seems to me it is in the fan revs coming to a slow stop after shutdown.
Checked for ANY interference. None. Fan spins nice and quiet in both directions.
John, it is definitely isolated to the fan.
Thinking I am going to pull the fan and check the assembly independent of the truck to see what the mystery noise it's emitting is.
Could be the bearing????!!!
Denny
Denny
Dieseldenny, no, I have never had any issues with my truck, 78,000 miles and nothing! The sound is sort of like a low frequency horn when the engine is stopping. I just put on a new belt and that did not change anything. Belt Tensioners all good too. My old dodge did a screech when shut down and my 2008 ford just the horn, or whoop whoop sound, never worried about it.
