2011 f250 no power when key on
Old 12-23-2016, 11:10 AM
Masterofyard's Avatar
Masterofyard
Masterofyard is offline
I went to replace a bulb in the truck then lost power in the cab to interior lights, no power when turning the key on, only certain things work. Mirrors will power fold, telescope. No power door locks, power pedals work. I have power to the main fuse box and the aux fuse box. Any help is greatly appreciated.
Old 12-23-2016, 01:40 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
Look at this diagram. They are hinting there are fuses in the body control module. Need to figure out if this is true and where it's located in 2011. I will keep looking.
http://www.revbase.com/BBBMotor/Wd/D...dPdf?id=878562
Old 12-23-2016, 01:46 PM
Franklin2's Avatar
Franklin2
Looking at this diagram
http://www.revbase.com/BBBMotor/Wd/D...dPdf?id=878537
They have a battery junction box (the fuse box under the hood) and the BCM or body control module which has fuses. I believe this is really the interior fuse box with a circuit board made into it. They used to call it the "central junction box" in previous years, when it was just the interior fuse box. Check all the fuses in the interior bobody control module). Even if they are not labeled with what you would think would be the interior lights.
Old 12-23-2016, 03:41 PM
Masterofyard
I checked every fuse on both boxes, all were good. Turned out to be the accessory delay relay.
Crewdcab
04-28-2016 12:01 PM
9228.bobcat
6.7L Power Stroke Diesel
06-11-2013 12:44 PM
nightowl_52
04-10-2007 12:03 PM
rudy84
Electrical Systems/Wiring
02-13-2004 11:21 PM
rudy84
02-13-2004 12:32 AM
Quick Reply: 2011 f250 no power when key on
