1978 - 1996 Big Bronco
check engine light and ignition
Old Aug 26, 2003 | 12:51 PM
bajabronco's Avatar
bajabronco
i have a 89, i have noticed on the inital start up of the day the check engine light will flash at about 3000 rpm right before it shifts, i have not noticed it of the initial start up. what could it be? also the igniton works some times and and sometimes it doesnt. it will go through periods where it work fine but then out of the blue it wont so i have to jump it off the relay, any suggestions? thanks.
Old Aug 26, 2003 | 09:10 PM
Capone's Avatar
Capone
Best thing to do right now is to pull the codes off the ECU....
