FrankenTruck F250?
Old 12-19-2016, 03:49 PM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
F250_Super_4X4 is gaining momentum as a positive member of FTE.F250_Super_4X4 is gaining momentum as a positive member of FTE.
FrankenTruck F250?
So, first a little about the truck;
VIN: X26HKCE6339 Should be a 1978 F250 Supercab 4x4. The VIN matches on door and Frame.
The door plate says build date is 04/77 (seems a bit early for a 78, especially a 4x4 SCAB)
The VIN serial number build date says JUN 1978 (CE6339)
Everything on the truck is 77 with a few exceptions being: 351M w/ C6 and married T-Case. The neutral safety is 77 on the steering column. The truck has original paint in accordance with the door plate yet the hood, grill, lights etc are 77.
The truck looks completely original to include seats, headliner etc.
Do I own a FrankenTruck or a Ford excess 77 parts from the factory truck?
Old 12-19-2016, 06:20 PM
meangreen92's Avatar
meangreen92
meangreen92 is offline
meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.meangreen92 has a very good reputation on FTE.
Maybe it was an early mule which somehow escaped the crusher, perhaps rescued by a Ford employee who would be able to pull that off...
Or the "4/77" is a typo.
Old 12-20-2016, 07:46 AM
F250_Super_4X4
I would agree on the typo except that everything on the truck is 77, except for married T-case
Old 12-20-2016, 12:02 PM
somethingclever's Avatar
somethingclever
somethingclever is offline
somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.somethingclever has a great reputation on FTE.
Late 77 and 78 F250's had married cases.
All 4wd supercab's were 78 and later vintage - no 77's.
Could your 78 have been built with 77 front rad support, grill shell, and column?
Hard to say. Seems unlikely for such key components and obvious external differences from what it was supposed to be, but I guess anything is possible.
Old 12-20-2016, 01:02 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The production date is printed on the Safety Standard Certification Label that is glued to the B pillar below the striker plate.
1978/79: The NSS is located on the transmission, C4 uses a different NSS than C6.
The hood is the same: 1973/79 F100/880 & 1978/79 Bronco.
X26 = F250 4WD Super Cab Pickup / H = 351M 2V / K = Kansas City MO Assembly Plant / CE6339 = 1978.
Compare the VIN on the Warranty Plate (riveted to the left door face below the latch) to the hidden frame VIN and registration VIN to see if they match.
People replaced damaged left doors with used doors. 99.9% of the time, they failed to install the original Warranty Plates on the replaced doors.
Old 12-20-2016, 01:47 PM
F250_Super_4X4
Yes the frame VIN and the door VIN match. The paint is original in accordance with the data plate paint code "F". So is it possible that this is a 77 SCAB 4x4?
My Dad always told me that if it looks, smells and tastes like poop its most likely poop.
Old 12-20-2016, 01:57 PM
NumberDummy
F = 1977/78 F100/350: Dark Brown Metallic
If it looks like a duck and quacks like a duck, it's a duck, but in your case, it might be a goose.
It cannot be a 1977, since the last 6 digits of the VIN (serial number) are different.
1977 serial number range: O00,001-O99,999 & X80,001-Z25,000
1978 serial number range: AE0,001-CK9,999
Ford would not assemble a 1978 in April 1977. Does the VIN printed on the Certification Label match the other VIN's?
Old 12-22-2016, 01:49 PM
march's Avatar
march
march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
My truck has a Safety Standard Certification Label mfg date of 4/78 and VIN X26HKCA4274 So your truck was built in Kansas City shortly after mine and must have a typo. After all "quality is job one"
alex211
18
08-07-2017 04:29 PM
tazerproof
25
12-22-2016 10:26 PM
gadiedrick
2017+ Super Duty
10-08-2016 08:20 PM
1978crewcab
07-25-2016 01:06 AM
csherrill
01-28-2016 04:07 PM
Quick Reply: FrankenTruck F250?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
