93 E-350 with 5.8L: oil filter removal tips?
Doing my first oil change on my "new" 1993 E-350 with a 5.8L.
I've seen some pretty stupid oil filter placements, and this one is definitely in my top five. So far I have had no luck getting the filter off using a variety of strap wrenches.
Seems like a gorilla mechanic must have tightened it on there.
Anyone got tips for removing? I already drove a screwdriver through it; didn't help (but it did drain the oil, at least).
Thinking of the razor blade on the gasket trick (which will be difficult, since I can only access one side of the filter) or using a torch to burn the gasket out of there.
That's what great about the pliers, I had a '94, 5.8 with the oil cooler, and the pliers were the only thing I could get in that tight spot to break the seal.
Of course, the last person that put the filter on might had over tighten it, like past the 1/4 turn, by hand, or the filter has been on for years........
I'm not partial to the Tekton brand, that was just the first picture that I found. Channel Lock and other brands make them as well. I would go with the longest handle set that will fit in your toolbox.
I wanted to thank you guys -- I got a set of those filter pliers and they were indeed what finally enabled me to get that !@#$%^ filter off the van. It wasn't easy, but they did work.
I got a set of two, one is 13.5" long and the other is 18" long. The 18" are too long because they interfere with the track bar. The 13.5" work all right.
It's still an incredibly stupid place to put an oil filter, though. Sure like changing the oil on my Cummins a lot better -- that's a ten-minute job.
